Racer
On my 87 Carrera, my brake pedal is considerably higher (closer) than either the clutch or the accelerator. Normal? It is somewhat annoying.
Preston Brown Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn) 1965 356 C Coupe | 2010 F250 (support vehicle) Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera |
The brake pedal looks normal. It's the clutch that looks low compared to my '88.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
I probably agree with Mr. Pizza--clutch lower than brake. FYI, I lowered my brake as part of my project installing racing pedals and learning heel-toe stuff.
Just curious, can you manually pull the clutch out? |
I also agree with Steve, if you can't pull the clutch out sometimes dirt and debris get under the clutch mechanism at the pedal preventing it returning all the way, especially if you track your car without carpets.
Tim
Tim Lynn 84 911 Carrera PCA E Stock #278 |
Mr Pizza?
Racer
Yes, the clutch pedal can be pulled out slightly, there is some free play.
Oops! I was doing something about food for the kids tonite...And, being a computer-geek and a scatter-brain, I read 'mushroom' off MASRAUM! Sorry! |
Preston,
Remove the pedal board and check to see if the brake stop pad has slid to one side. This happened on my '72 and, just like your pedal cluster, the brake pedal was way too far forward. I removed the wooden pedal board and saw the problem immediately. It took 5 seconds to fix, and now my pedals are properly aligned. Jeff
"Not all who wander are lost." -J.R.R. Tolkien |
I have adjusted my brake pedal so it is lower than the clutch (at maximum braking it's even with the throttle for heel/toe shifting)
Mike - PBG, FL '14 958 Cayenne GTS '05 997 C2 - SOLD '79 911 SC Widebody PCA, NASA, PBOC - SOLD 2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3 |
With a 15mm wrench you can loosen the lock nuts on either end of the pedal shaft (remove carpet and wooden plate). By turning the shaft, you can lower or raise the pedal height. Retighten the two locknuts when it's where you like it and you're done.
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! |
