-   -   Bilstein Strut Question (http://forums.pelicanparts.com/porsche-911-technical-forum/132317-bilstein-strut-question.html)
jhoughton 10-20-2003 09:03 AM
Has anyone ever see a stub axle on a Bilstein Strut wear funny? After a couple of days trying to deal with what I thought were loose bearings, it is the stub axle that wore more on one side that is causing the problem. Also, does anyone know if I need to replace the entire strut assembly or can the axle just be replaced? Is it worth looking for a used assembly?
Thanks,
Jay
Wil Ferch 10-20-2003 12:57 PM
I've heard that you need to mike the shaft in 90 degree intervals to assure a good one. Some are worn in the 12 and 6 o'clock positions and OK in the 9 and 3 o'clock positions. Causes weird-to-locate vibration and shimmy problems. Sometimes can be rewelded, ground out and hard surfaced to repair. Otherwise...must get new ( or used) housing, minus hydraulic guts ( around $200-$220, last time I looked ).
--Wil Ferch
