braddb_82SC's Avatar
help ID oil leak - photos
I dropped the engine (for the first time) today on my '82 SC in order to get at a pesky oil leak. My first thought upon viewing the front of my engine was that the main seal was blown and the flywheel was slinging oil out the top vent onto the bell housing. The oil appears too high on the housing to be coming from the usual suspected locations such as the breather gasket/hose, the oil cooler thermostat or the oil pressure switch. I’m going to replace these parts anyway. Should I also replace the main seal? I had not intended on splitting the engine from the transmission.
Thanks,
Brad
'82 911SC Coupe
Old 10-20-2003, 12:46 AM
72 four door's Avatar
I would its not that bigga deal it would really be awful if it started leaking after you put it back in. preventative maintenence goes a long way.Check your oil cooler too.
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 10-20-2003, 04:39 AM
GB83SC's Avatar
Good time to check or replace the clutch. Yes replace both front and rear main seals. Also do the intermediate shaft cover seal just under the rear pulley.
While its out:
Valve adjustment
spark plugs
oil cooler seals
check intake runner hoses (if puffy replace them)
pressure switch
O-ring thermostat
crankcase breather gasket.
good time to replace wires,distributor cap if needed.
New fluid in trany
Clean and instal new engine noise mat.
Take it slow, and have fun!
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 10-20-2003, 06:21 AM
Thanks.
I think I will go ahead and replace the front main seal. Perhaps I'll replace the rear seal as well. I had already intended to replace the intake runner hoses and gaskets. The parts are in a box along with the rest of $150 worth of while-I'm-in-there parts, purchased from Pelican. Looks like I'll be placing another order soon.
The valves and plugs were done less than 1000 miles ago. I wish I had waited until I decided to drop the engine to do those. The clutch has only 25K on it so I'll skip that replacement project for now.
I'm still courious though - does this leak evidence suggest the normal engine-top leaks?
Thanks again,
Brad
'82 911SC Coupe
Old 10-20-2003, 09:47 AM
GB83SC's Avatar
Hard to tell from the pictures you provided, it actually looks very dry at the top, compared to ones I have seen leaking from that area.
George
1995 BMW 525I
Old 10-20-2003, 09:59 AM
Mine leaked in that area from the thermostat. I would definately re-ring it while you have access.
gary
Old 10-20-2003, 10:25 AM
