clnilsen's Avatar
Help Me identify What's on this Oil Cooler
I bought a Used Carerra Oil Cooler, and I'm trying to identify some parts on it. (see picture)
I'm trying to identify what parts A, B, and C are on the cooler.
Thanks!
Chuck
1980 911 SC Targa *Sold!*
2003 Boxster
2013 Beetle Turbo cab
Old 10-20-2003, 05:07 PM
a= thermal fan switch probe commercially available in most auto parts stores as part of a hayden fan relay control kit and it will activate your fan to come on at about 180-190 degrees- when you buy the rest of the kit (it will come with new probe)- use this one
b= ground wire hook up from oem wiring loom when c is installed
c= original fan switch that came on at 260-270 degrees- do not hook up to this one! that's too hot
Old 10-20-2003, 05:33 PM
Hilbilly Deluxe
emcon5's Avatar
Doesn't look like an oil cooler, it looks like a story.
My interpretation:
"C" is the factory thermostat. The factory thermostat works by closing to ground, completing the circuit in the trigger side of the fan relay, which leads us to....
"B" looks like a terminal for a ground connection, because the ground through the mounting bracket was inadequate. The previous owner then realized that the factory thermostat sucks, because it doesn't turn on until it gets to 240° F, which is too damn late, which leads us to...
"A" which is an aftermarket thermostat to turn on the fan at a more reasonable (safer) temp.
EDIT: Dave beat me by 3 min
Tom
82 911SC Coupe
GTI Cup #43
Old 10-20-2003, 05:36 PM
clnilsen's Avatar
Thanks! That was easy!
chuck
2003 Boxster
Old 10-20-2003, 05:52 PM
factory temp ~245, but you guys were close
Old 10-20-2003, 07:57 PM
