Randy Webb's Avatar
Fuse OK but dead radio and cig. lighter
What am I missing here? My radio and cig. lighter are dead in my '75 S, but the fuse is fine (as are all the others). The radi is not too imp. but the cig. lighter runs the V1 and that is a very useful accessory.
Is there some other fuse (inline) somewhere? Wiggling the fuse (to get rid of any corrosion) doesn't help either.
Are these things on a relay perhaps?
Old 10-21-2003, 09:58 PM
Send a message via AIM to fintstone
There should not be a relay. I am suprised that your radio is on the same fuse as your lighter. Is your radio stock or aftermarket? If aftermarket, I would guess that the installer just tacked the radio wire to the back of the lighter since they are close. TI would look for a broken wire under your dash.
The radio should also have an inline fuse under the dash too. The lighter fuse is too big to protect a radio.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 10-21-2003, 10:35 PM
Noel's Avatar
Randy,
Try twisting the fuse around in your fingers while it is installed. I've seen good fuses that don't make connections because of slight corrosion. Also check the Relay.
Noel
Old 10-22-2003, 06:06 AM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Check the ground. Brown wire on a faston connector under the dash. They seem to come loose pretty easily on mine....
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 10-22-2003, 07:09 AM
steve911's Avatar
try replacing the fuse with a new one. I had a similar situation with my power windows - fuse looked good, but windows didn't work. replaced with new fuse (I had already shined the contacts) and voila - working windows. now if I can only get my windshield washer sprayer to work...
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 10-22-2003, 08:54 AM
RETIRED
Joe Bob's Avatar
There can also be an inline fuse somewhere....but the above suggestions are right on....replace the fuse and put a multimeter on the wire to see if there is a short somewhere. If you can't find the short, there may be an imperceptable break in the wire.....replace the wire.
2012 ML350 3.0 Turbo Diesel
Old 10-22-2003, 09:20 AM
