Can webers and new exhaust help!!!(PICS)
I've posted some pics of my car as of today. I would like to improve the performance and look with weber carbs and SS heat exchangers and exhaust over the winter months. Can anyone tell me where the best price and place to purshase these items are. I live in Canada so shipping may be a problem..
IS THIS A WASTE OF MONEY FOR A 911T???? WILL THIS IMPROVE MY PERFORMACE SIGNIFICANTLY????? COULD A CARB REBUILD DO THE JOB??? Please give me your thoughts... I AM FAIRLY NEW TO THE BOARD THANKS IN ADVANCE...CHRIS.. ![]()
Hi
SSI's shoudl not make a difference in performance, as they are basically the same as what you have only stainless steel. Unless that is, you have major leaks in your exisiting exchangers. Webers ( in my car) are pretty similar to the Zeniths in terms of size, so there again, performance should be similar between them. I'm curious... where did you take your car to be serviced?
1970 911 t (sold) 1985 MR2 (sold) 2011 GT 5.0 2007 CRV |
Thanks reg for the reply
I think the weber carbs and SS exhaust will just finish the car, thus eliminating that awful under carriage and backfiring... I have my car serviced in Oakville @ Mantis racing. I've only had good experiences with them, why do you ask? can you spot something??? Chris....
1970 911T Euro |
If you're going to spend money on carbs, then buy the PMO (adverts in most p-car related magazines). Most of the webers out there are getting pretty worn out I think.
That said...PMO are bloody expensive! $3500 canadian-ish
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
Pelican Parts sell PMOs
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
... I only asked for a reference as to your garage Chris. They guys at Mantis did well at the Targa Newfoundland this year.
I've had my car serviced at Furtmair in Kitchener and Uli did a pretty good job.Actually the Canadian dollar is riding high these days so buying from Pelican is easier than ever.
Hey Reg
Send some pics of your car!!!! I would be interested to see Chris
1970 911T Euro |
I have the following parts available if interested.
Sport exhaust factory heat exchangers weber 40 IDA carbs All set up for a early race car. Send me an email and I will forward the details. JLogan@clair.com |
The 911, particularly the T, is not choked off by either the Zeniths or the early exhaust system.
To get more power out of the T you need more fuel, more air (displacement increase, cams) or a higher compression ratio (pistons). I raced a guy at Summit Point in a J-class 69 911T (110 HP, 2194#), he actually finished one spot ahead of me in the race (I was .9 seconds faster but spun in lap 10), never underestimate the power of suspension and handling improvements.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Here she is:
nice car!!!
1970 911T Euro |
My 911 has a 2.4T with SSIs and recently rebuilt Webers. You do not want to spend $2000+ to achieve this level of performance. 2.4T has 7.5:1 compression, which is the biggest problem.
