I am moving to Ohio where the winters are cold! What weight engine oil should I use? I have a 1978 911SC.
I dont plan on driving that much in the winter. Thank You, Bob |
I am in same boat right now and have searched and searched the posts for the many different options. I think i will just go with what the manual says. "SAE 30". I believe this is 5W SAE 30 though right? "10W" is thicker for hotter temps. (allright i am quitting right there...i don't have a clue...anyone have any thoughts?). Kinda like to do this change in the next day or so.
joe 68 L |
Joe, 30w is a straight weight oil. whereas your 5/30 is a multiweight. I was thinking of using 10w/40, but just wanted to see what others thought. Ya, you are in Cleveland! I will be in Columbus. Thanks!
Paraphrasing and repeating one of my earlier posts; why not use what the manufacturer reccommends?
According to the owners manual for my '78, for year round use: "... use multi-grade oils SAE 10 W-50, 15 W-50 or 20 W-50. The 20 W-50 oil should not be used at constant temperatures below +5 degrees F/-15 degrees C." From this it would appear 20W50 would be fine for winter (in Maryland, NOTE: Ohio gets colder), you might look at using a 10W40 or 15W40, both should be readily available in any name brand. It would also appear that 10W30 (I wouldn't consider 5W30) is much too thin (except, perhaps, in the most extreme cold, e.g. consistantly below zero F.). Jerry M '78 SC |
Castrol 15W-50.
Oops, I mean Castrol Rx 15W-40.
going in a half hour to parts store.... georgie, why that?
no comprende'. Readily available by me at Autozone, Advance Auto, etc.
Just changed my oil Saturday and put in what my mechanic recommended-- Valvoline 20w50. I live in Detroit. I'll take it out on warm days (35F) a couple of times. The 20w50 is what I want to run normally, so when spring comes I have the oil I want already in there. It will be fine for the few days in the winter.
Bill G. '68 911 Ossi Blue coupe |
Mobile 1 0-40 in the winter months and 15-50 in the summer months...
Rick 88 Carrera Targa -- There are only those that know and those that do not!!! -- |
i'd been running 10w30 until recently and switched to 20w50. Didn't know the proper wt. until another Pcar owner told me that I should run the heaVIER WT. oil. Hope it didn't cause any damage.
1985 911 Carerra Cab 3.6l 1998 Dodge Ram 2004 Toyota Tundra Quad Cab |
20-50 will not hurt you car! Dont loose any sleep.
George My Owners Gallery Page 1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running. 1995 BMW 525I 2001 Highlander- kid mover |
And, as the car was built in '78 the parts would be reasonably loose by now and have plenty of room for 20-50 to circulate well.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/ www.914club.com |
Information Junky
Re: Winter oil recommendation
If it were my SC in OhiO, I would plan on ZERO winter driving. Those knuckle-heads salt the roads like you wouldn't believe. "Winter Cars" corrode fast in that area. Last edited by island911; 10-21-2003 at 07:51 PM.. |
Nope... Don't drive when the snow starts to fly here in MN. Time to put her away for some R&R during the snowy months. However, up to that time, I drive and enjoy no matter how cold it gets...
