Nathan M's Avatar
Question How do I get the cam plates off?
I'm pulling the engine apart and everything's gone very smoothly - until now. I've removed the 3 camshaft retainer bolts on each side, removed woodruff key, shims etc but simply cannot get the retainer plate to budge. Is there a knack to doing this or am I missing something? The retainer seems very soft metal and I don't want to damage anything.
Advice appreciated.
Nathan
3.2 Coupe
Old 10-22-2003, 03:42 PM
Super Moderator
cstreit's Avatar
I had to GENTLY pry mine up with a thin screwdriver that had tape on the tip to prevent scratching.. Often a slight sealant is used on the gasket behind it, which makes it stick more.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-22-2003, 03:46 PM
Friend of Warren
I too used the flat thin screwdriver to break things loose then used a pair of needle nose pliers with tape on them to pull the covers off.
Kurt V
Old 10-22-2003, 06:04 PM
you can see the edge of the plate from behind. you can pop it out from behind by levering a flat blade screwdriver off the cam tower.
206 637 4071
Old 10-22-2003, 06:15 PM
Super Moderator
cstreit's Avatar
No kidding JW? I never thought to look to the other side... But that makes sense! Thanks!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 10-22-2003, 08:05 PM
