Switched from Marelli to Bosch
My marelli broke it's distributor cap and I am switching to a Bosch. Only problem is I cranked the engine over when I had the Marelli out and the Bosch not in. So now (correct me if I'm wrong) I have to:
#1 set engine to TDC. The mark to the right in the set of two close marks on the crank pulley. #2 Align the rotor tip with the notch in the distributor and point the rotor tip towards piston #1. #3 Bolt everything down adjust timing and I should be good to go, right? Just double checking to see if I'm missing anything as I plan to do this tommorrow. And yes I've read the 101 projects, and the engine rebuilding book. Any hints would be appreciated. Thanks, Sam |
err make sure your cams and distributor are in alightment as well. aka you're at TDC before your power stroke
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Okay, I'm not quite sure what you mean by: "make sure your cams and distributor are in alignment.." Care to shed some light on it for me. Thanks, Sam
Sam Gonzales '69 912 2.0 -6 power |
Okay I know you guys have to have some tips for a porsche newbie.
sammy,
there are 2 TDC's. One "on" cam and one "off" cam . I don't remember which one you need to set it to. What you need to do is open up your intake valve cover and watch what the camshaft for cylinder #1 is doing. I think you need to set it to have the rotor point to #1 when you have TDC and both valves are closed on cylinder #1 aka just before it's power stroke (just leaving the compression stroke and about to fire for the power stroke) Hope this helps
Is there an easier way to determine TDC for #1(not pulling off a valve cover), can I just install at TDC try to fire it up, if it doesn't run, pull distributor rotate crank pulley 360 degrees reinstall and try again. This can't be the most delicate method but is it possible to do this way, or am I risking damaging or breaking something? Thanks, Sam
Bird. It's the word...
Set your crank to Z1 and observe where your rotor is on the distributor. There is a notch at cylinder 1. If you are on Z1 and cylinder 1 start it up and tune with a scope.
John Forcier Current: 68L 2.0 Hotrod - build underway |
My pulley does not have a Z1 mark only a pair of marks, and then a couple of marks unevenly spaced.
914-6 GT Resource Page
Marelli Twin-Plug Distributor...
Hello Sammy! Is your "Marelli Twin-Plug Distributor" for sale? What size engine is your Marelli installed in? Early or late style case?
Does your distributor look like this? here is another photo... Please let me know. THX!!!Armando http://www.pbase.com/9146gt |
Author of "101 Projects"
I would guess his is a single-plug distributor.
Sammy, if your engine is at Z1, it could be at TDC for cylinder number one, or TDC for cylinder number 4. The best way to tell where it is located is to remove the valve covers on the left hand side and check to see if the rockers wiggle when you're at Z1. If they wiggle, the valves are closed, and you're at TDC for cylinder number one. They shouldn't both wiggle if you're on TDC for cylinder number four. -Wayne -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
To find TDC can't you also hook up a compression tester to #1 and turn the engine over until you see the highest pressure readings? I did that when I replaced my dizzy. Compression testers aren't that expensive.
Mike
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
Another way to tell TDC w/o removing covers is to monitor compression on the upstroke while turning the crank with a socket on the fan nut. All plugs should be removed and you will need a compression tester. You have to be able to turn the crank with fairly rapid motions so that the air will move the gauge. On the exhaust stroke, you will get nothing on 1, but a jump in the needle on 4. After a couple of trys, you should know that you are TDC compression for no. 1
Friend of Warren
Or if you don't have a compression tester and don't want to remove the valve cover then do just as you describe in your initial post. If the car won't start or runs incredibly rough, you are 180 degrees off on the distributor. Pull the distributor, turnt the rotor 180 degrees and reinstall. You will then have it in correctly.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Sammy,
Don't try to run the engine with the timing 'guessed at' ... an engine fire can result if you set the timing to fire on all the cylinders while the intake valve is open! Your crank pulley should have a total of three notches associated with cylinders one and four ... as you rotate engine clockwise there will be two notches close together for 35° and 30° Before Top Dead Center, then a bit further over, the Z1, or TDC notch. There are isolated notches for Z2 and Z3 for cylinders #3 and #6, and #2 & #5, respectively. Jack up the left side of the car 8" - 10" ... and pull both valve covers, then turn over engine until both rockers are loose on cyl #1, and look for the third mark/notch as decribed above. Use a test lamp to see when your points open, and rotate distributor body until points open when the TDC mark coincides with the notch on the fan housing or crankcase vertical split ... as you turn the engine over with a wrench on the alternator pulley nut. Check your work by turning the engine over a few more times and MAKE SURE the test lamp comes on each time the TDC -- Z1 notch comes up for cylinder #1!!!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Mike
Sammy,
Maybe this will help ...
remove #1 plug. turn engine clockwise by hand and notice the resistance as each cylinder pumps up it's compression on the way to TDC. when you reach #1 there will be no resistance. line up the Z1 on the pulley to the fan housing mark, and install the distrubutor with the rotor tip ponting to the notch on the distributor body. you will be in the ballpark enough so it will run. then set the timing with a light.
Excellent, thanks for all your advise guys I'm going to go ahead and pull the valve covers and give it a try today. Sam
