Send a message via Yahoo to Jimal92
Question 911 Tach
Hi
I got a 1972 911E with a bad tach redline 6,800 max 8000RPM. I can get a tach from a 1969 912 only goes to 7000 RPM will it work and read properly through the RPM range?? Please let me know. Thanks James
Old 10-22-2003, 11:09 AM
derek murray's Avatar
I do not believe a 912 tach will work in your car. The 912's have 4 cylinders versus your 911's 6 (i.e. different electronics). The 1969 gauge is also smaller in size (i think) and mounts with a bracket as opposed to your E's friction / gasket fit.
I may have a tach for sale in the next week or so... let me know if you are interested.
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 10-22-2003, 11:42 AM
Early_S_Man's Avatar
Porsche Crest
jimal,
No, the 912 tach has TWO strikes against it, besides the fitment issue!
1. The 912 tach is designed for a battery-coil ignition, not a CDI-system, and the trigger signal from the points of a CDI-system isn't correct -- in terms of what the tach is looking for!
2. The 912 tach is a 4-cylinder tach, and wouldn't be accurate, even if the trigger signal matter was OK!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-22-2003, 12:44 PM
