Part # help??
Can someone tell me what part this # refers to?
996.352.621 Thanks, should be a boxter part. |
You are short a couple numbers.
Tom |
the only other # on it was 20667901??? maybe im losing it....
Generally speaking, Porsche part numbers are in this format:
xxx.xxx.xxx.xx What is the part? Maybe someone can look up the number. Tom |
I think it is a boxter S front caliper, someone said it is a rear, I checked on a rear that was on the car, and that wasnt the same. I just need to know if it is front or rear.
If I am reading it right, the part numbers for Boxster S brake calipers are:
Front Left 996.351.425.11 Right 996.351.426.11 Rear Left 996.352.421.13 Right 996.352.422.13 |
That number doesn't match 996 brakes either.
Tom |
| All times are GMT -8. The time now is 03:07 AM. |
