Carpet glue
Hello all,
What is a good glue to use when installing carpet. I was just going to use some subfloor adhesive or something like that but was wondering what you guys have used.
Thanks,
Mike
Old 10-23-2003, 04:44 PM
You do not have permissi
john70t's Avatar
I'm not sure what are the best products to use, but FWI Home Depot sells carpet padding by the foot pretty cheap.
I'd recommended it because it made a big difference in how solid the car felt when I first got in (i.e. work boots din't feel like they were going to go through the pan), but each to there own. Also now is the time to check/correct rust and seal it with POR15 if there is going to be any sitting water.
I used lightweight constuction adhesive(not Liquidnails) from a caulk tube under the padding and a whole lot of 3M general purpose adhesive under the carpet.
Old 10-23-2003, 05:25 PM
72 four door's Avatar
I used the 3M spray you can get it at home depot
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Shaun @ Tru6's Avatar
I picked up a gallon of contact cement at home depot to redo my 84. I liked the total control of how much and where the glue went (brush on with various sizes). Excellent adhesion. Used about half gallon.
Good luck, this is one of those jobs that really makes a big difference every time you get in the car.
Tru6 Restoration & Design
Old 10-23-2003, 05:32 PM
I used 3M Super 77 to do most of the carpet, but the floors and tunnel carpet are held on with 2" industrial-strength velcro, so they can be easily removed.
1968 911L
2004 Dodge Dakota SLT Plus
Old 10-23-2003, 06:01 PM
buttjoint's Avatar
The PROS use 3m spray
Old 10-23-2003, 06:03 PM
Friend of Warren
I can't believe anyone uses anything other than the 3M spray. Holds very well yet you can pull the pieces up if necessary later.
Kurt V
Old 10-23-2003, 06:09 PM
Great!! Thanks guys. I think i will go ahead with the 3M spray, sounds clean and easy.
Old 10-23-2003, 06:12 PM
Todd Simpson's Avatar
I did my carpet with some 3M and some Wurth. The Wurth sprays heavier, sets up faster, overall easier to use.
Old 10-23-2003, 06:13 PM
andrew15's Avatar
I used the 3M super yellow (i think its 77) - worked really well and as a bonus I felt goofy from the fumes for hours after!
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 10-23-2003, 07:28 PM
Eric Coffey's Avatar
The 3M stuff works well, but general contact cement (as Shaun mentioned above) is a better way to go IMO. That way, you don't have to worry about "overspray", and it will give you a stronger bond.
Old 10-24-2003, 03:41 PM
Used User
Zeke's Avatar
Originally posted by Wayne at Pelican Parts
So strong, that if you try to remove the carpet after it's glued, you will tear the carpet internally...
-Wayne
Why would you want to do that?
Seriously, the spray is a good overall product to use. The w/s adhesive in the tube would be good for difficult areas or edges you tend to pull up with use and abuse.
My FB page: www.facebook.com/oddjobfix
Antique and Collectibles Repair and Restoration
Old 10-24-2003, 05:28 PM
CHILI's Avatar
Ok, I'm resurrecting this thread because my new carpet came today. Wooohoo! Thanks Manny (code7rpd)!
Anyway, I've used 3M spray on lots of projects, but can't imagine using it inside of a car because the **** floats everywhere! It even gets on my glasses! Doesn't it end up all over the windows, dash and wheel?
Does anybody know of a brush on type of glue that would still be able to be pulled up without having to be the Hulk or ripping the carpet?
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 01-07-2004, 03:14 PM
I used the 3M spray on my carpet install and it wasn't a problem. I would apply a small amount to the area of the car I was gluing to and then would spray the carpet piece outside the car in the driveway. FYI, the 3M spray cleans up nicely with paint thinner.
Old 01-07-2004, 03:26 PM
greglepore's Avatar
The stuff in the 3m spray can is available in a tube-its called Fastack-pn 08031-bicycle guys use it to glue sewup tires on their rims. I'd still spread it with a brush, as the nozzle on the tube puts out a thin stream.
Greg Lepore
85 Targa
Old 01-07-2004, 04:52 PM
3.2 CAB's Avatar
I thought the 3M spray had an adjustable spray nozzle. FINE----MED----HEAVY.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-08-2004, 02:08 AM
Carpet glue
We make carpet sets for 911's and have found the the brush on contact cement (3M) is the best way to go. Be sure and purchase the NON enviormentally friendly stuff (it smells alot stronger but holds alot better too). It can be purchased at most home improvement stores (Home Depot/Lowes Etc). Pick up some throw away brushes and some cheap narrow rollers while your there plus some mineral spriits for clean up.
Bob
Old 01-08-2004, 07:03 AM
CHILI's Avatar
Thanks Bob! Actually the carpet set is from you guys! Manny never installed it and needed some money to fund another project, so I picked it up. Can't wait to install it. From what I can see, it looks great!
Chad aka "Chili"
Old 01-08-2004, 07:41 AM
