Door Liner Adhesive
Does anyone know of an adhesive for plastic door liners that is reusable 2 or 3 times?
I'm tired of having to make a new plastic liner or put more glue on when I'm putting the liner back on my door.
Never enough time to be doing the fun stuff. '70 914-6 2.2 MFI #269 '71 914-4 2.0 '85 911 Carrera |
I think 3M makes a good sealant for this stuff. It tends to stick when you want it to and come apart easily when you want it to. I can't remember the name of it though.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
3M makes a product called "PhotoMount" that might work... no experience with it other than using it for its intended purpose. It is used to mount photographs; so it remains sticky without setting things down permanently. Any good graphic supply store should stock it.
'70 911S 1002938 '70 Ducati Mark 3D 350 |
BUTAL (sp??) tape. Comes in a 3M or NAPA box. Paper backed so you can apply it. Comes in I think, a 10ft. roll. In with the auto body stuff, like windshield sealers.
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor |
I used "DA adhesive" from NAPA - which is used to attach sanding discs to Dual Action sanders - these need to come off later. It has worked well for several remove and replacement cycles.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon |
3M 777 spray adhesive works better than the 3M Photo Mount product designed for adhering paper to paper. Be careful not to get the overspray on things, apply to both surfaces, let dry slightly and then position into place
Harlan Chinn Pacific Northwest Region 1998 Carrera S ArcticSilverMetallic 1982 911SC PazificBlauMetallic Last edited by Harlan Chinn; 10-24-2003 at 12:43 AM.. |
You do not have permissi
I've used "body-dope", the claylike stuff string that comes in a roll they put between panels to keep them from ratttling. Can be used indefinitly as long as it's clean.
Meanwhile other things are still happening. |
I would rather be driving
I have had good luck with bicycle tubular tire cement. a little goes a long way. Its usually a few dollars a tube which will easily do both doors
Jamie
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
