ckmaggie's Avatar
Successful Valve Adjustment... and a pic
Just wanted to thank all of those who replied to my message after my botched first attempted at a valve adjustment. As recommended, I waited a few weeks to clear my head (I was very frustrated), then took my time to carefully adjust the intakes valves on both sides, buttoned her up and then lifted her as high as I could to do each exhaust side. I was sooo excited this a.m. when I turned the key and that dreaded sewing machine ticking was gone... It really was much easier the second time around.
Thanks again for the encouragement and certainly all the great info on this board.
I decided to post my first pic. No reason, just wanted to show the car off.
Chris
Chris
1985 Carrera
http://www.pelicanparts.com/gallery/ckmaggie
Old 10-26-2003, 11:35 AM
Silveresrty911S's Avatar
Nice car Chris.
Hope my first adjustment is as succesful as your second
Isn't this BBS great!
Rick
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 10-26-2003, 11:46 AM
Toothzilla's Avatar
Hi Chris,
Was it a pain in the butt to get the blower and intake out of the way? I'm planning on doing a valve adjustment on mine in a few weeks. Also, was it too difficult to adjust the intake with the car jacked up?
thanks for your help,
chris
Old 10-26-2003, 12:57 PM
ckmaggie's Avatar
For my 3.2 engine, all I needed to remove on the left was the heater elbow and hose. Quite simple. And on the right I moved the a/c out of the way and then removed the airfilter (as per the bentley manual)
I adjusted the intakes w the car level. No need to worry about any oil for them. For the exhausts, I put my car stands on a 2x6 and set them a max height; did the side then closed her up and switched to the other side. I lost maybe 6 oz. of oil at max w this process. In fact having the car set up this way gave me easier access to the exhaust valves on cylinders 1-3 due to the cat converter in the way.
Good luck
Chris
Chris
1985 Carrera
Old 10-26-2003, 01:44 PM
GB83SC's Avatar
Great work!
Valve adjustment (scratch that from the fear factor list)
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 10-26-2003, 01:53 PM
TopsailBeach's Avatar
Nice car. I've done mine twice now, and have decided that the procedure sounds much more complicated than it really is. By draining the oil the night before, it isn't even that messy. In fact, the entire major service routine isn't bad with Wayne's bundled parts and pieces.
Congratulations!
A J Burns
'07 Guards Red Carerra 4S 911 Coupe w/Aerokit
'86 Iris Blue Carerra 911 Coupe (given to my son)
'63 Morgan Tiger Cub w/original Atomic 4
Old 10-26-2003, 02:41 PM
