-   -   First post, and some project pictures (http://forums.pelicanparts.com/porsche-911-technical-forum/133233-first-post-some-project-pictures.html)
87calbear 10-26-2003 05:10 PM
Hey everyone! I've been lurking for a while now and thought I'd say hello and post some pictures of my 72T Targa project. I've got the front part of the unibody, gas tank, and suspension stripped and painted with POR-15. I replaced the original front suspension bushings, and upgraded to Boxster brakes (I don't really need them, but I couldn't help myself from tinkering). Here are some pics of my progress so far:
http://forums.pelicanparts.com/uploa...1067215986.jpg
http://forums.pelicanparts.com/uploa...1067216011.jpg
http://forums.pelicanparts.com/uploa...1067216028.jpg
Here's a shot of my daily driver:
http://forums.pelicanparts.com/uploa...1067216400.jpg'
Thanks to all SmileWavy
Ken
tangerine911e 10-26-2003 05:33 PM
Welcome to the board Ken! :)
Looks like a great project. Any other pictures?
What rims are you going to run around those brakes? Make sure you keep us up to date with progress.
Ash
Kevin Stewart 10-26-2003 05:43 PM
Man that por-15 looks good, Nice job, Kevin
87calbear 10-26-2003 06:05 PM
Thanks guys. I've got a fairly random assortment of pictures from the project so far since I've only been taking pics when my hands have been clean. Which is not very often. Here's a shot of the front suspension before assembly:
http://forums.pelicanparts.com/uploa...1067219719.jpg
Here's a shot of the car when I started stripping the paint on the car. Originally I was just going to repaint the car (signal yellow), but the project has expanded.
http://forums.pelicanparts.com/uploa...1067219818.jpg
The projects for the winter are installing a front oil cooler behind the right battery box, and replacing the main fuse blocks with new ATO style blocks. Should be fun!
Ash: The car had 15" replica Fuchs on it when I bought it (15x7 front, 15x8 rear). They clear the Boxster calipers with no problems. They look a little goofy small, but I kinda like them.
Ken
Zeke 10-26-2003 06:24 PM
Aw, come on now. Isn't that really a new car you found somewhere and you want us to believe that the pics of the inner fenders are the same car as the one in the driveway?
Seriously, very nice work.
pjv911 10-26-2003 06:39 PM
looks great. It almost looks like all new sheetmetal. POR-15 you say ha. I will have to get some for future use. How long is the drying time ?
Kurt Williams
Kevin Stewart 10-26-2003 06:56 PM
ATO style blocks. my fuse block sucks, is this a direct bolt on? Kevin
notmytarga 10-26-2003 07:09 PM
Are you going to remove the Targa bar before the repaint - How did you decide?
87calbear 10-26-2003 07:51 PM
I'm sure my wife wishes that I would have just bought a newer 911. But that's not what I wanted ;) .
I used 2 coats of POR15 rust preventative paint and 2 coats of POR15 chassis coat black top coat, 2 days for all 4 coats. It seems like the coatings got stronger with time after I was finished with the top coats. Definitely stick to the instructions, and wear a mask and gloves.
I'm pretty sure that I can get the ATO fuse blocks to work. I got them from waytekwire.com. I stripped and repainted the trunk with POR15 silver. Here's a shot of the new blocks next to the original fuse blocks:
http://forums.pelicanparts.com/uploa...1067226273.jpg
I had to trim the mounting ears off of the fuse blocks and drill some new mounting holes. Without the mounting ears, they're almost the same size as the original fuse blocks. I've got them mounted to an aluminum plate that I'll mount to the original fuse block brackets.
I haven't figured out what I'm going to do with the targa bar when I get to painting the car, but it looks like it's easy enough to remove.
Ken
Chuck Moreland 10-26-2003 09:10 PM
That looks like a nice clean, rust-free tub! What did you do to remove the factory undercoating?
87calbear 10-26-2003 09:35 PM
There were a couple of spots in the unibody that were rusted through. I had to weld in some small patch panels. I used some wood chisels to srape off the majority of the undercoating (shown here on the gas tank):
http://forums.pelicanparts.com/uploa...1067232733.jpg
and then finished it off with a wire wheel on my 4.5" angle grinder (easily the most useful took for this phase of the project). 12000 rpm rocks!
http://forums.pelicanparts.com/uploa...1067232878.jpg
Ken
pjv911 10-27-2003 05:14 AM
Wow ! So you have a few hours invested ! Thats dedication ken. Good work.
Kurt Williams
