Paulbav's Avatar
some pics
Here's some pics of my new baby also I think i have put to much oil in it how bad is that? It's going into the garage on friday so I shall get them to change it anyway willl it be allright to drive 30 miles there?
Cheers Paul
1990 944S2
(Gone to a new home)
1989 911 3.2 Carrera sport
slate grey
Old 11-04-2003, 01:05 PM
Nice looking P-car.
As for the oil, be sure to check the oil level with the motor warmed to opperating temp and on level ground. If you check the oil when it is cold you will get a reading that the level is too low. When the motor warms up the oil will overflow. The first day I had my P-car I added two quarts thinking it was low when I first started the motor in the morning. I ended up having to drain two quarts after the motor warmed up.
Of course, waiting to check the oil level assumes you have about 8-9 quarts of oil in system and just need to bring the oil to proper level.
Edit: One other thing. Do not trust the oil guage at first. Check the oil level with the dip stick. After a while you can compare the oil level guage with the dip stick readings to determine the accuracy of the guage.
Old 11-04-2003, 01:13 PM
Very Nice P-Car. For a second, I thought you were talking about your new son or daughter. But a new Porsche is almost as exciting.
For Sale - check it out in the "Auto's for Sale" section
California Triple Crown Winner - 2002
*2005 Markleeville "Death Ride" 5 Pass Finisher. 129 miles & 15,000 ft. of climbing
*California Triple Crown Member (3 Double Centuries in 1 Year)
*2003 Giant Carbon Fiber Road bike with Topolino Wheels + a lot of goodies
*2000 Torelli road bike - Campagnolo Chorus equiped + a few goodies
*1999 Litespeed titanium, full-suspension mountain bike Shimano XT equiped + a lot of goodies.
Bill Carcot
1979 911SC - Sold (Searching for a Boxster)
2000 BMW Z3
Old 11-04-2003, 01:18 PM
Paulbav's Avatar
I did the check on level ground and with the engine idleing cold to hot the temp needle was in the middle of the first section when i last checked it and the level was nealy twice the top mark on the dip stick do i need to take some out or will it be ok to run to the garage?
Thanx
Paul
1990 944S2
slate grey
Old 11-04-2003, 01:20 PM
Glasgow 911SC's Avatar
Up to temperature would be about the 2nd white block on the gauge. I would definately take some out. The stuff comes out at some rate if you remove the drain plug underneath the tank so it might be better to syphon some out the tank filler.
A lot of people reccomend keeping it half-way between the min & max marks on the dip-stick.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 11-04-2003, 02:12 PM
Oh..nice car by the way. Did you import it yourself or buy here?
Chris
Old 11-04-2003, 02:13 PM
Paulbav's Avatar
Bought it here £8ooo.oo bargin I thought
1990 944S2
slate grey
Old 11-06-2003, 12:21 PM
MN
Sarah's Avatar
nice pictures. congrats on getting it.
n11...that is a very nice picture too.
87 930 Blk/Blk
Old 11-06-2003, 01:26 PM
dickster's Avatar
nice, and great colour, and price!
make sure the oil pipes under the front offside wing (fender) are hot when you check the oil. leave it idling (can take 20 mins) to get them hot.
Rich
'86 coupe
"there you are"
Old 11-07-2003, 05:36 AM
Paul Franssen's Avatar
Paulbav - nice car! Re your oil not that I'm poking fun at you, far from it, but it looks to me like nearly ALL beginning Porsche owners make the very same mistake: to trust the oil gauge!
It happened to me: when I drove my Carrera from the garage where I bought her, after some 10 km slow driving I took a look at my oil level gauge and, Lawd behold!, the meter's in the red she's not filled with oil. So I drove even slower to the first gas station and put a liter in her... within 15 minutes thereafter, the gauge was showing "maximum" level... Fortunately I hadn't put all that much too much in, and so I didn't have to remove any oil.
Below project might be suitable in case of a mild to moderate overfill (NOT FOR A BAD CASE OF OVERFILL!)
Without Prejudice
PROJECT: SIPHONING OFF SUPERFLUOUS MOTOR OIL
Tools:
some rags, paper towels,
a thinnish plastic 1.5 yard long plastic hose
an empty oil tin (with screwcap) cap. abt. 2 quarts or so...
I would recommend you to board your car together with the above tools (at least) and
(1) drive slowish for about 15-20 minutes at a constant lower-rev speed and watch that oil gauge. If if even start moving towards a maximum level, stop that car and
(2) keep the engine running, and check the oil with the dipstick (it's in the back of the car ). Hopefully, it won't show an overfill!
(3) In case there is a clear overfill situation, then I would shut off the engine immediately and stick the hose into the oil-filler neck and +++carefully+++ suck some oil into the hose (PLEASE: NOT INTO YOUR MOUTH!!!!) and see if you can siphon some oil off into a suitable can with screwlid.
(4) In case there is not any serious overfill, your mechanic can take care of changing the oil (or do it yourself, for that I recommend you buy "101 projects" from Mr. Wayne Dempsey (future Nobel prize candidate and Owner of this website).
Gut luck!
Belgik
1988 Carrera 3.2L
Old 11-07-2003, 06:34 AM
