d.s d.s is offline
d.s's Avatar
Porsche Crest clutch on 996??
hi guys
i just got my car (996 2003 4S) from a major service (40,000km) and it had its yearly check up...everything was fine.. but i aked the service manager to have a look at the clutch as i felt i was a bit weak and when i shift the gears i feel that the rpm goes higher(cant explain it)... that wasent normal..so i was told at 50,000km i would need to replace the clutch...isnt that TO SOON? i THINK i was told that it may cost around $2200 u.s...
this is my FIRST stick car so my driving may have been a factor, im only 23..
so is this normal?? how long should a 996 clutch last? and what should it cost at a dealer?? is it a LONG process?? do they take out the engine? gearbox?
p.s i drive the car EVERYDAY in a city with somewhat busy traffic
thanks guys
Old 10-28-2003, 05:01 AM
Crusty Conservative
silverc4s's Avatar
You have most likely been slipping that clutch more than you realized as you learned to drive a "stick shift" car. Replace it now, before you need a flywheel as well...;-(
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 10-28-2003, 05:16 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Also worth noting, if you bought the car to do a lot of city driving then you should have picked up a tiptronic, would have made things easier. Or learned to drive standard on another vehicle.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 10-28-2003, 06:39 AM
