Senior Member
Low Oil Pressure
On a cold engine oil pressure will climb to 3 to 3.5 (keeping RPMs under 3000) as the engine warms though it stays in the 2 to 3 range ever when bringing RPM up to 4 to 5,000 rpm
The funny thing is that when the needle climbs it makes a sudden drop as if it loosing the signal or a pressure valve opens.
Not burning oil, no leaks and engine sounds fine. I am hoping it is a electrical gremlin with the gauge or the sender.
How does one verify the actual oil pressure with out using the on board gauge and or how does one test the gauge / sender to verify they are reading correctly.
Oh last time I really drove it (ashamed to say it) back in July all was well. Have taken a few short trips here and there and all was fine then as well. This past Saturday I noticed the issue.
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 10-30-2003, 08:38 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Omar,
I've got a mechanical guage you can barrow if you'd like. I used it when I had the same problems. (turned out to be a worn out engine but that shouldn't be your problem)
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 10-30-2003, 08:39 PM
Senior Member
Would love to. Can I meet you someplace next week as I am on vacation and want to get this resolved before the next drive.
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 10-30-2003, 08:40 PM
IROC's Avatar
This sounds exactly like what my oil pressure gauge was doing. It ended up being the sending unit.
I have a good sending unit at home (but not sure of the PN). Let me know and if it works on your car I'll send it to you for nuthin...
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 10-31-2003, 05:05 AM
Tim Walsh's Avatar
Omar,
It was only about $15 at the autozone so it's not worth your time or mine to drive from g-boro to Concord for it.
Tim
1973 911T
2005 VW GTI
Old 10-31-2003, 05:10 AM
Senior Member
Mike, Thanks I will check on the P/N and get back to you.
Tim, Which one is it and I will go pic one up. Where do you hook it up to take your readings
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 10-31-2003, 06:58 AM
Tim Walsh's Avatar
Omar,
I just picked up a generic one. Mine hooks up right next to the breather in the back but I belive yours in in the front just to the right of the fan. Mine came with american fittings so I used some teflon tape to seal it. It leaked a little but it gave me a good reading.
Tim
1973 911T
2005 VW GTI
Old 10-31-2003, 07:04 AM
