-   -   MSD for '79 Turbo Rookie Questions (http://forums.pelicanparts.com/porsche-911-technical-forum/133823-msd-79-turbo-rookie-questions.html)
Germaneighter 10-30-2003 07:58 PM
Will the MSD 6AL/MSD Coil work on an otherwise stock '79 930? Will the over boost switch and run on relay still operate?
Does the 20 degrees of spark cause detonation problems?
Anyone running this ignition on a Turbo?
Thanks,
DLG
bb 10-30-2003 08:12 PM
I am going to hook up the msd 6btm(w/boos control) in the next couple of weeks. I am also going to use the MSD timing box so that the msd will run the whole thing. It is going into my 2.7 Turbo.
Oscar
dean 10-31-2003 04:15 AM
I have had the MSD setup on my car for 2 years. No problems. The overboost sw. is not related so it works and I assume the run on relay would work also but I don't have one. The only hard part is fitting the unit in.
lendaddy 10-31-2003 05:08 AM
I run an MSD 6AL with blasterII coil. No problems.
