-   -   Wipers cycle when I "Flash Brights" (http://forums.pelicanparts.com/porsche-911-technical-forum/134054-wipers-cycle-when-i-flash-brights.html)
RickKlem 11-02-2003 08:52 AM
Each time I pull back on the arm to flash my brights my wipers cycle once and then turn off. How do I stop this?
Also , my headlights will go to highbeam on "flash" but will not change to highbeam by pushing the stick forward. I think there is some contacts on the stick that I need to "bend"
Help
Rick
RickKlem 11-02-2003 12:34 PM
burp,
masraum 11-02-2003 12:54 PM
yep, you MAY be able to bend the contacts in the wiper switch, but if you don't install a relay kit at the same time you will be better off replacing the switch. I think Pelican has it for about $75. You'll need to pull the steering wheel to bend or to replace switch.
You will be better off replacing the switch.
