-   -   Difference between 930 an 935 engine (http://forums.pelicanparts.com/porsche-911-technical-forum/134344-difference-between-930-935-engine.html)
caliber60 11-04-2003 10:33 AM
What's the difference between 930 turbo and 935 enginie? Is 3.6 liter the maximum you can go on the turbo engine without suffer the reliability? Does the 993 Twin-turbo uses the same engine as the 930 turbo(one additional turbo) or it's a new design engine? Thank you for answer many questions.
5axis 11-04-2003 10:37 AM
Re: Difference between 930 an 935 engine
1) just about everything except the case.
2) I think CMW has built some gawd awfull expensive 3.8 turbos
3)No it's a new motor.
RickM 11-04-2003 10:42 AM
This chart will answer all your 911 and variant engine spec questions....
http://www.calweb.com/~thom/engine-types.html
targa911S 11-04-2003 11:52 AM
well lets see..
930/02 Carrera 3.0 200hp @6,000 rpm. 188 lbs of torque @4,200 rpm.
930/50 turbo body 245 hp @ 5,500 rpm. 253 lbs torque @ 4,000 rpm
930/72 motor fitted to factory 935, 590hp @7,900 rpm. 438 lbs of torque @ 5,400 rpm.
That's all.
targa911S 11-04-2003 11:56 AM
I also saw a 934 1/2 yesterday. It had a turbo on it that was so big it looked like a washing machine! An ex Brumos car.
Eric Coffey 11-04-2003 11:59 AM
Originally posted by targa911S
....930/72 motor fitted to factory 935, 590hp @7,900 rpm. 438 lbs of torque @ 5,400 rpm.....
And the last evolutions of the 935 put out nearly 800 horsepower!
