Randy Webb's Avatar
torsion bar sizes
Is there any way to determine the size of the aftermarket torsion bars in my car without taking them out?
Old 11-07-2003, 03:26 PM
diy83sc's Avatar
Read Wil Ferch's article, http://tech.rennlist.com/911/pdf/settings.pdf, specifically page two with the paragraph beginning with "We also need accurate car weight....." The rest of the document should give you enough to get an good approximation. Car weight seems to be the key, though.
Old 11-07-2003, 06:17 PM
Randy Webb's Avatar
Huh??
I want to know what the non-stock bars are that are in the car now.
Maybe you are telling me to back-calculate an approximation based on the car's wt. and the droop in the spring plate -- if so, I don't think that will be very accurate.
Old 11-07-2003, 08:30 PM
CHILI's Avatar
Call the PO and ask.
Ok, but seriously, I don't think there's a way to tell without taking a springplate off.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 11-08-2003, 12:19 AM
diy83sc's Avatar
I haven't done it, but that's how I would do it... calculate back to the torsion bar size. But to get at the droop, you'll need to remove just about all but three of the spring plate cover bolts. So, you may as well, remove the last three and pull the spring plate or call the PO.
Old 11-08-2003, 06:49 AM
Randy Webb's Avatar
THe d$&&% thing is, I had it all apart 2 years ago to renew all the rubber parts -- but I didn't check the sizes then.
Old 11-08-2003, 11:03 AM
