relays in rear
I'm trying to figure out which is which in the back of my '75 911.
There are 5 holes in the metal carrier under the cover, laid out in a square with a hole in the middle of the square. One relay is in the middle hole. The other one is on the RH (passenger) side, at the rear (bumper end). The other 3 holes are empty - no sockets or relays. Can anybody tell me what these 2 relays do? Thanks!! |
Relays
On my 76 911S, one is the heater blower relay and I believe
the other one is the rear window defroster if you have that. I have porsche wiring diagrams if you need more info. 76 911S 66 912 V8 68 912 2.2 with nitrous 70 914 project car |
Top of page says: "The 1975 911S and Carrera models have a modified relay plate."
993 Last edited by cowtown; 11-09-2003 at 04:51 PM.. |
Wow -- thanks -- is that from the repair manual?
Shop manual (paper binder).
993 |
