dc96819's Avatar
400hp which way
Iam restoring a 81sc and and would like at least 400hp.Which is the best way to get thier.Buying a twin turbo $23k or doing some mods on a single turbo.What year engine should i use if its a single turbo.I would go with a single if the price was right.
Old 11-14-2003, 02:11 AM
Call MM and get an E-Ram and a Cool Collar. This will give you about 450RWHP on a stock SC bottom end.
Don't believe anything the doubters on this shameful BBS will tell you. Your 915 is plenty capable all the way to 700HP.
Audi B7 S4
Old 11-14-2003, 02:17 AM
Ohhhhh boy.
Can't believe I blew my 911th post on this.
Oh well.
Audi B7 S4
Old 11-14-2003, 02:39 AM
Forgot to ask, what is your budget?
Audi B7 S4
Old 11-14-2003, 02:41 AM
Owwww comon! Am I the only bloke having a slow Friday? Someone else bite before this goes OT!
Audi B7 S4
Old 11-14-2003, 02:48 AM
Bump
Audi B7 S4
Old 11-14-2003, 03:25 AM
dc96819's Avatar
budget
Well if i get a twin turbo for 23 i wouldent want a single for 23.
Old 11-14-2003, 04:01 AM
Following this logic, you can run up to four turbos for 46.
Audi B7 S4
Old 11-14-2003, 04:06 AM
Where are all the other HP Junkies tonight?
Audi B7 S4
Old 11-14-2003, 04:07 AM
buy a stock 930 engine and spend about 10k extra for the mods and you will have your 400hp.
1978 911SC Targa
2003 Cad. Esc.
2002 GMC Sierra
2002 Acura Stype
1999 Honda Pass
1987 Chev PU
Old 11-14-2003, 04:35 AM
At what point in your restoring of a $12K car did you decide you had to have a $23K engine?
Audi B7 S4
Old 11-14-2003, 04:38 AM
Tinton's Avatar
dc96819,
Try put a little more info in the posts. Like why you chose 400HP and what you are after. 400HP from a twin turbo wont necessarily be the same 400HP from a single turbo. Engines will have different characteristics.
Where is the twin turbo engine for $23k? Wouldn't you want more power for that dough.
Also, who bothered to rate this thread and why did they chose 3 stars?
Porsche 993 & Honda CBR250RR
Old 11-14-2003, 05:01 AM
Hi Tinton, I rated it 5 stars because it looked for a while like being the most entertaining thing happening here tonight.
Somehow, it got demoted to 3 stars.
Audi B7 S4
Old 11-14-2003, 05:15 AM
dc96819's Avatar
changes
This car is like my faveroite shoe hard to part with it. Since 1984 it went from a sc targa to a turbo look then a slant nose then a convertable now a twin turbo but wondered how can i get that to work till i found this site.A single tubro would be fine with a little more than avarage power.Engines for sale
http://www.911pcar.com/Porsche_Parts/porsche_parts_engines_complete.htm
My projects never end
Old 11-14-2003, 05:16 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Well, if your talking about 400 flywheel power, meaning roughly 340 to the wheels isn't too bad. You could probably do it for about 10k or so assuming your doing the work yourself. Double that if your going to have a shop do it for you. Change but retain like 8:1 compression, because you don't need high boost to make those numbers. Next port the heads if it's an 80-83. Get rid of the cis and go to some type of stand alone using a 3.2 carrera intake manifold. With that compression, you can probably get a fairly large turbo, and still not have too much lag. Plus there will probably be a lot of little things to take care of as well. All though, even with the aluminum cased 915 it probably won't last very long with that kind of torque and power.
BTW, only reason to go to twin is if you have a fat wallet and are REALLY concerned with lag, otherwise don't bother.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 11-14-2003, 06:14 AM
dickster's Avatar
its got to be easier to get that power with twins.
and more kudos
Rich
'86 coupe
"there you are"
Old 11-14-2003, 06:15 AM
Amac's Avatar
Are you replacing the motor, or do you want to
mod. the one you have?
Best case, would be replacing with 3.3 turbo,and
add a few goodies.
Worst case, tring to build a 400hp n/a SC motor for
less than $20K.
"Never go faster than you can stop"
85 - 930 (750hp)
Norwood motec 3.5 twin turbo
Old 11-14-2003, 11:43 AM
From what I understand a '79 turbo motor can be made to put out about 400/450 horse without changing the fuel system radically.
You gonna stick a cage in that thing to tie the front to the back with all of that power?
Old 11-14-2003, 12:37 PM
Harlan Chinn's Avatar
Buy one from a guy that already has one sorted out for sale, like Roberto of our local PCA here. His puts out an honest 450hp and is a flamethower. It's a white 87 930 3.3 motor with all the upgrades. louce161@comcast.net Email him to see if he hasn't already sold it.
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 11-14-2003, 12:45 PM
Senior Member
Superman's Avatar
My car is quite a bit of fun to drive with about 205 hp. 250 would be a kick in the pants, particularly if it had carbs and shorter gears.
400 hp is a whole different ball game. A poster above suggested a roll cage which would connect your four shock towers. The reason for this suggestion is that 400 hp will twist one of these cars. That kind of power will put most drivers into the ditch.
Also, that kind of power chews up trannies, CV joints, etc. If you have a lot of money and desire a car that race-car-driver-wannabees have no business driving, then......GET A TURBO.
Mocha 1978 911SC. "Coco"
Old 11-14-2003, 01:05 PM
