Is there a check valve in the brake booster
Is there a check valve in the brake booster ?
When vacume is applied to the booster there should be a check valve in line somewhere, is it built into the booster or is it somewhere else ? This is on a CIS 77 car. |
Yes, it's right where the vac line goes into the booser.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
