-   -   Big Red Light to replace Clock in Dash (http://forums.pelicanparts.com/porsche-911-technical-forum/135272-big-red-light-replace-clock-dash.html)
DanS911 11-13-2003 11:32 AM
It's always the little details isn't it
Superman 11-13-2003 11:46 AM
If an adjustable switch is fitted, I'd suggest adjusting it so that it comes on when pressure falls below something like 10-20 psi or so. Oil pressure idiot lights are usually designed to come on when oil pressure is, like, 4 psi or 0 psi or something. At this pressure, it's actually a "Your engine has just been destroyed" light.
Unless you're driving my Datsun pickup. I add oil when the oil pressure gauge starts falling to zero.
dotorg 11-13-2003 12:00 PM
Hmmm. Now I wonder why I've never seen that light turn on on my car at all. Guess I've got more than a missing oil temp sensor.
How does the oil pressure light work? Is it tied to the oil pressure sender? My pressure gauge works, but I have never seen a warning light come on, even at idle or while starting.
Superman 11-13-2003 12:08 PM
The oil pressure idiot light sending unit (switch) is a different critter. Mine is located on the oval plate at the rear center of the engine near the firewall. It's about as big around as a nickel.
msailer 11-13-2003 12:31 PM
That's exactly what I was looking for. Got close last night, but never stumbled upon the right numbers.
Now to find someone who sells GROTE, in particular these parts. Seems very few places sell GROTE.
Originally posted by rsr808
Something like these:
http://www.grote.com/cgi-bin/product.cgi?familyid=B0001
http://www.grote.com/cgi-bin/product.cgi?familyid=J0024
The have other goodies on their website to choose from as well:
Hope this is what you're looking for.
Vintage911Racer 11-13-2003 03:03 PM
Big REd Light
Here is one I did with parts from Autozone.
http://forums.pelicanparts.com/uploa...1068499859.jpg
http://forums.pelicanparts.com/uploa...1068499632.jpg
Mine comes on at 15lbs..... Works great. I actually had a oil line come off at an event. the light came on right away. Shut motor off, no harm no foul, no problem. Motor was fine.
TMH 11-13-2003 03:18 PM
I've used these guys for lights: http://www.thelighthouseinc.com/asp/default.asp
Also, these guys have some great deals on LED lights for trucks, and many are the same sizes: http://www.partssystems.com/home.html
Tom
Ho Hum 74 11-15-2003 08:13 PM
That light looks like something out of a Mel Brooks movie!
89turbocabmike 11-15-2003 08:22 PM
Any NAPA or Big Truck supply will have that lens and rubber grommet. They are standard size used on commercial trucks and all brands are interchangable.
}{arlequin 03-29-2004 02:25 PM
Mark,
What do you have to do to "set" the particular pressure to trigger the light?
Vintage911Racer 03-29-2004 02:36 PM
The dual pole sending unit (one pole for Oil pressure and a pole for oil light) that I bought had the option of different activation pressures. Screw it in, attach the leads, and bingo. It is set.
I think this is a standard part you can order from most high performance parts stores.
Grady Clay 03-29-2004 03:18 PM
Mark,
There is a Porsche part oil pressure switch that has a 917.xxx.xxx.xx part number that was used on 935s and many others. It switches at about 45 psi and is adjustable over a fairly wide range of pressure. I keep mine at about 40 psi. When the engine is hot and only below about 4500 RPM does the light come on. I use a large trailer tail light above the dash.
Believe it or not, I can turn the light on under extreme braking at 8000+ RPM.
There is another important switch.
I didn’t use an alternator, just a shaft in place of the alternator. That meant there was no indication if the fan belt was not working. Porsche has a little air pressure switch with part number 908.xxx.xxx.xx that can run another warning light.
I’ll see if I can find you the part numbers. They are regular Porsche racing parts, no mistery.
Best,
Grady
Ho Hum 74 03-29-2004 03:42 PM
Do you have your oil tank modified? A baffle will help this dangerous situation.
Tristan
Grady Clay 03-29-2004 04:00 PM
Tristan,
Yes, extensively on 911s and 914-6s. When I raced a 935K3 I could turn the light on in certain circumstances of breaking regardless of how much oil was in the tank.
I think this is the reason why the GT3-RSR (and earlier) has the relocated oil sump tank in place of the engine cooler.
Best,
Grady
Todd Simpson 03-29-2004 07:09 PM
Why would a baffled oil tank help? The only oil-pump pickup point is in the sump.
The pressure circuit to the bearings comes from the tank. Oil drawn from the sump just goes back to the tank.
