-   -   Search Help "pop off valve" (http://forums.pelicanparts.com/porsche-911-technical-forum/135484-search-help-pop-off-valve.html)
William Miller 11-12-2003 10:22 AM
How do I do a search on "Pop Off Valve"
I can't get the syntax right on joining the words.
Maybe I should just post my question and somebody will tell me to search.
Superman 11-12-2003 10:26 AM
Do a search. Kidding. Perhaps "popoff"
Schrup 11-12-2003 10:27 AM
What's your question, The best advise I can give is to make sure the pilot bit in the holesaw is only a 1/4 inch past the edge of the saw or you may drill a hole in your cold start fuel chamber when you cut the hole for the valve. Don't ask how I know.:o
SpeedracerIndy 11-12-2003 10:51 AM
OUCH! Also, a right angle drill is really helpfull. I didn't use one and even though it worked, I spent forever mounding the puddy on there to get the thing to seal. It's amazing how small of a leak will send the CIS into fits.
Superman 11-12-2003 11:01 AM
Oops. forgot to warn you about the metal parts in there, Paul, but I thought only the later SCs had them. In any event, I'm not sure it hurts them much to have holes in them. They may not be necessary at all.
William Miller 11-12-2003 11:05 AM
No use on the search, too many posts with popoff. I'll post my question.
