Registered Loser
Am I a Hazard?
I have a really loud clunking sound coming from the left rear end of my car. Mechanic thinks it might be a bad CV but can't find any damage on the boots or the axles. Since money is tight these days, I am inclined to ignore it and crank up the stereo. So am I a prudent and financially disciplined economic citizen or am I an accident waiting to happen?
Owner of a wrecked 944 |
Friend of Warren
Really loud? You are an accident waiting to happen. Your cv joints can quite easily go out even though the boot is in good condition.
Kurt V No more Porsches, but a revolving number of motorcycles. |
i think you know the answer to that
Rich ![]() '86 coupe "there you are" |
Registered Loser
Okay, then dumb question #2...what, exactly, are CV joints and what do they do?
they are joints in your drive shafts (between gear box, and hubs) that allow the drive shafts to move up and down with the suspension.
make sure all lugnuts that secure tires onto car are tight.
had the same clunking/knocking sound a while back and that was it. loose tire |
Friend of Warren
Course you can always keep driving with a bad cv joint. That is right up until it breaks and takes out part of your exhaust and beats the bottom of your car until it looks like the surface of the moon. Other than that, really no problem.
CV = Constant Velocity. CV Broken = No Velocity. I would get it fixed ASAP or at least stop driving until you have the $$$.
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
Not Quite Banned
I would not want to be in the car behind you when this lets go. Better hope the the outcome is just a slow coast to the side of the road to await tow....
Thomas Owen 1972 911T 1972 911S |
Non Compos Mentis
CV's are relatively cheap.
Fixing a car that had one let go isn't. You decide. |
Yes!
John Adams 1980 ROW 911SC |
Registered Loser
Wow, thanks for the info. I'll take the car off the road right away until I can get it fixed. I actually took the car to two shops (one was an independent Porsche mechanic while the other was a Porsche dealer) and both seemed strangely unconcerned by the clunking. The most either one said was "sounds like a cv" but neither offered to replace the CV's because they appeared to be okay. So I figured I should ask the true (Pelican) experts before I went spinning into a guardrail.
NOTE: Driver is more mechanically clueless than he appears.
Janus,
Replacing the CV's are not really too difficult of a job. As long as you have a safe jack and a sturdy pair of stands, you can probably do it yourself.I would recommend that you replace the entire halfshaft. (the axle shaft between the two CV joints). It is usually cheaper in the long run. It is very odd that you would have a bad CV if the boots are in good shape. I would recommend that you go to your local book seller tonight and pick up our host's excellent book "101 projects for your911". It has two pages with pictures dedicated to this job.
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/ 1970 911S, 10 sec 67 Beetle (300 rear wheel HP) RGruppe#252 |
Just in case check that the sway bar mount hasn't torn away from the body, under certain circumstances that can make a clunking noise at the rear of the car. I only mention this because it's not clear how closely the two shops looked at your car. If they just went by your description without checking things out you may want to verify that the CV is the problem.
When do you hear the clunking? Around corners? Upon acceleration? Sitting still?
Eugene (Formerly) at Pelican Parts Pelican's E-Commerce Guy, 2003-2011 2001 330i Sport 1983 911SC Coupe (sold) |
Team California
Get it checked by someone willing to actually diagnose it. Might be something that can be ignored for awhile, might be a serious issue.
Denis |
Not to step on toes here, but I have a similar noise, that only occurs while coasting in 1st gear........I've been told it's a c/v joint, so I plan on replacing the axle on the off season here. Does that symptom sound right? Already had the tranny rebuilt, and the noise existed before and after.
regards,
Jon '85 Targa (recently acquired by Coollx) '02 Carrera 4S (holy moly...I'm in heaven....in the snow too) '06 BMW 325i (gone and forgotten) '03 Honda Odyssey (more dings every day....thanks wifey) |
Registered Loser
). Actually, after rebuilding and re-installing the tranny, I ended up spending lots of $$ having the passenger side CV and sway bar stuff replaced because I had apparently accidentally destroyed them. My mechanic has often said, "I don't know if I make more money fixing your car or fixing your mistakes." Quote:
Owner of a wrecked 944 Last edited by Wrecked944; 11-14-2003 at 02:37 PM.. |
