Looked at Pelican parts for new plugs and found that I have a choice of 3. The Bosch +4 plats, WR7DC, and WR7DP.
I think that the DP's are oem stock, so what is the DC's? or should I just go for the +4's? My '86 Carrera only has a Steve Wong chip. no other mods. I will probably buy Magnecor wires at the same time. Anyone shed some light on this. Cheers se
'86 911 Carrera coupe (silver) needs a lil' love ![]() '90 VW Corrado G60 (yellow) close to death ![]() '90 VW Passat wagon (white) a lot closer to death '97 Chevy Astrovan (moms car) POS died! ![]() '03 GMC Safari conversion van
Don't go with the platinums, early ignitions don't react very well to platinum plugs. I'm not sure about the other two, but your choice has been reduced to two.
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
DP's are also platinum, DC's are copper. Go with the DC's, there's no advantage, performance wise, with the others. BTW, DC's are stock.
Jerry M '78 SC |
I agree. I switched to platinum double electrode and my 3.2 seemed to run with a little less "pop". I'm going back to copper single electrode on the next oil change/valve adjust.
CWL '86 Carrera Coupe '88 Carrera Cab '02 525i Sedan |
Certified Pre-Owned
WR7DC
'84 Carrera Coupe |
BTW, this brings up a question of my own (not to hijack your thread or anything). Has anyone tried those new iridium plugs yet?
My son recently purchased a Chevy pickup,a 1999 I believe with about 75000 miles so one of the first things he did is oil,filter,air filter and spark plugs to have a good baseline to start with,after all these changes the truck had a little bit of a high speed miss to it,you guessed it he purchased twin electrode platinum plugs,I told him to change them to plain jane plugs(AC Delco copper) and the truck ran great!!! Now this is a vehicle with modern ignition and fuel injection,in my opinion platinum is junk.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Driving member
I have posted here before about this. I put platinums in my car and it got so bad it would shut down. It couldn't hold idle. I put the old original bosch plugs that I had taken out and put them back in and it ran great again.
I traded that junk for the original bosch and I haven't looked back. I have even heard that you could burn a piston with those things. I have not personally seen this but a guy I know who used to race porsches says that he has seen it happen. I know that it has been shown that some things can be improved in what the factory shipped out but I think for the most part it is always best to use oem equivalent parts. Trying to get more performance out of these cars is usually not going to work out by using the latest greatest filters, plugs, air-rams etc. It just ain't that easy
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. Last edited by jester911; 11-29-2003 at 01:58 AM.. |
here is another option
wr7dtc it's the same as the wr7dc but it has 3 ground electrodes.
big AL '77 911 |
Has anyone tried surface gap plugs?
I use them in my RX7...with great results. Bob
Bob Hutson |
Let's see...3 plug options listed, and mine is the 10th response? Oh well, what the Hell...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
I have the NGK Iridiums in my '87 Carrera and feel they don't give the same punch as the standard copper core version. My next try is a little known plug from Delco called Rapidfire. Everyone on the Corvette BBS swear by these. I put a set in my truck and noticed an improvement over the Autolite. The part no. for the Carrera is #4. Problem is Delco doesn't publish much info. for applications for these plugs so I'm guessing about the part no., looks correct.
I have to also chime in with a neg on the plats. I have them on another car and the difference is noticeable in a negative way. They were $5 per too! I won't try them again.
todd 86 cpe |
Certified Pre-Owned
Again, IMO if the vehicle was originally shipped from the factory with copper plugs, stick with copper. Platinum is the better plug because the material is self cleaning by nature *if* the ignition system of the vehicle is so designed that it has a high enough igniton system output to fire the plug (jump the gap with adequate spark.) Many cars do not. Say a distributorless igniton in an M3 with a coil pack at each cylinder, or a VTEC with a higher output ignition, you'll go 50k miles of abuse before the need to change plugs. And as the plug wears, the gap increases, but who cares, it has enough electrical snort to jump the gap on the plug. Not as good an idea with a 15-20 year old 911 ignition design...
'84 Carrera Coupe |
In the Porsche I run copper. In my 2000 Solara w/Supercharger I switched from platinum to iridium (I needed a slightly colder plug than stock with the supercharger and decided to try iridiums). Both work great for their application.
Pat
Current: 07 S4 Avant, 06 Volvo S60R Sold: '74 911, 01 986, 93 Volvo 240 |
Hey movin, let us know how that experiment goes.
