cicsprog's Avatar
Question Loose Electric Mirror
My drivers side electric mirror has come off. Looks like it has a collar that rotates around to lock it in place. But how do you rotate that collar once the mirror is in place. Basically there is not much room. Any help would be appreciated.
Jason
88 911 CAB
Old 11-15-2003, 11:59 AM
carreradpt's Avatar
Jason are you talking about the glass coming out or the flag itself coming off the stalk?
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 11-15-2003, 12:21 PM
cicsprog's Avatar
Glass coming out
Jason
Old 11-15-2003, 12:22 PM
cicsprog's Avatar
Got it...that collar has some spokes at the bottom. So I powered the mirror until it was tilted all the way up. Then I was able to reach the spokes and lock the collar inplace. I am sure that would have only cost about $35 at the P-Car Dealer. Thanks Anyway! Now time to drop the engine.
Jason
Old 11-15-2003, 12:42 PM
Erakad's Avatar
Bently talks about a locking ring at the base of the glass, assesible through a small hole on the bottom of the mirror frame. If you take the entire mirror off and turn it over (or stand on your head) you can see it. They show inserting what looks like a screwdriver to tighten or loosen it. If my scanner worked I could just scan it and show you...but hasn't worked since I moved
Rob
Black 1983
911 SC Coupe
Old 11-15-2003, 12:44 PM
cicsprog's Avatar
Yep...saw the hole. But tilting the glass worked too. Thanks! Get that scanner fixed. Something else might break on my car.
Jason
Old 11-15-2003, 12:47 PM
