Cone fileters on a 3.2 or 3.6
Who makes the best cone fileter and adaptor for the 3.2-3.6 engines? I had a really nice one that was basicly a black circular disc. The cone filter mounted on it with about a 5" opening at the base of the filter. It was very clean. Some have a large elbow on them and the filter is more rearward possible allowing water to fall into from the deck lid opening.
The best cone filter is not a cone filter at all, it is the factory filter configuratin with a K&N and a few 2~3 inch holes in the cover.
Why is the stock air box with holes better than a cone type of filter?
Powerhaus makes a nice one. I have it.
The stock 3.2 airbox is not a bottle neck. Forget the K&N (more dirt in your engine). The only advantage to the cone filter on a 3.2 is easier access. From what I've read, removing the filter all together won't make any difference, well maybe a little - a 2-3 hp loss.
-Chris |
(Chris) What makes you believe this, "Forget the K&N (more dirt in your engine)"? I've been running K&N for years on various platforms, including offroad and have excellent results with the filter.
Bill |
K & N does indeed let more dust into the engine... dyno tests on Carreras revealed little or no power gains compared to stock papper filters.
K & N may be washable, but paper filters best... Good reading: http://www.seansa4page.com/resource/airfilter.html |
Wow, I had always thaught the K&N filters were the best, but I guess to flow all that air some dust must be able to slip through. Interesting...
Yupp...people often forget that corrugated area of paper filters is fairly high compared to K&N filters that use more porous material.
Yeah but...the KN is oiled...and is expected to get an initial dirt layer built up to aid in filtration..... I'm on the fence on this one...seen too many posts from both sides of the argument and not a lot of conclusive evidence of superiority either way.
---Wil Ferch |
How often are you guys changing your paper filters?
Is their a big differance in flow from a little dirt in the filter? I think if their was any advantage to the K&N type filter one of the car manufacturers would use them. Do any new cars come with coton/oil filter? |
Well.... my 1970 Karmann-Ghia had an "oil-bath" filter from the factory !
---Wil Ferch |
Mine definitely makes variable whistle [varies with throttle]. I think it sounds like a toilet valve closing/opening. I do like the less clogged look in the eng compartment and improved access on the side there. The AirFlow Meter loses a support and that bothers me. Not sure I'd get one again . . . Since I haver barely used it, I've actually been thinking about unloading it.
todd 86 cpe |
I love the sucking sound and the whistle the K&N makes on the autobahn!
Steve W
Yes I have a pitching sound. It bothers me since my car isn't a Turbo, but sounds like one :rolleyes: Still I haven't put the stock airbox back on because I love the deep aggressive sound from the K&N during full acceleration. Maybe a socalled open "cup" airbox would be the golden compromise for me :) But then again that means spending money.... :( |
Rgds Steve |
Interesting thread. I recently made the "mod" to my 3.2 stock airbox. I decided to forego the swiss cheese route and simply cut the entire face off of the box which was pretty easy on my table saw for nice neat oem looking lid. Much like the Carrera Cup lids fabby sells without the $175 side effect. The result is very nice.
Much more intake noise, obviously (I have the K&N) The sucking sound really gets to your ears whilst pulling through third up to 100+. Overall I think it is a good mod. I would be afraid that with a paper filter that thing might get sucked in or distorted with the face of the box off. Seems to pull a little harder in all gears according to the butt dyno but who really knows. Benefits such as increased induction noise, more room in the engine bay, cleaner looking bay, and seemingly slightly more power. As an aside, my mods are the Steve W chip, fabby cat-by-pass, RUF muffler. The only other "performance" mod is to check the opening of the throttle for full opening. I will say that all of these mods together really wake up the car, easily netting some great HP. Of course a dyno will tell but I know the car is faster, smoother, pulls harder and is a really joy to drive. -Jeff nolift911@hotmail.com |
Jeff, Got any pics?
I apologize - I gain so much info from this site and everyone takes time to post pics and stuff, makes me look like a slacker. I will try to get some pics posted soon. The short answer is I bought a new mondo teeth blade for the table saw and it cut the box like butter. Really fine teet for cutting laminates and paneling. I just used the fence as a guide and off it came..took about 3 minutes. I used 1000 grit paper on my jitterbug sander to smooth out any rough edges and it looks pretty good IMO. Tons of room in the bay now and yes, I can finally get that lower back latch hooked without being a contortionist. -Jeff nolift911@hotmail.com |
I don't have big fingers and I can never snap all 4 clips down on the airbox. Cone filter cure that problem.
jthwan22
Quite frankly, that is why I got my cone filter. The non-existent performance gain wasn't. todd 86 cpe |
It seems some guys have noticed a sucking noise when cutting open their airbox cover which I never noticed - and it suddenly dawned on my why. The induction noise comes from air entering the intake mouth at the relatively small bell shaped entry. I didn't think the intake bell was large enough, enough to disturb the laminar airflow and create noises and some restriction. When I modified my airbox, not only did I cut open the airbox cover, but I extended the mouth of the bell shaped intake with Bondo and some wire reinforcement. It looked like a pink doughnut around the intake flare, much like the intake venturi stack on a F1 racing motor. This allows the mouth to draw air smoothly from all the way around the mouth, as much as 180 degrees from the opposite direction of the intake flow. The intake sound was clean to me - no wierd sucking noises, just a nice roar (whaaaa.....) at full throttle past 4000.
Interesting observation Steve. I noticed a the huge sucking noise much like a friend's 72T with MFI. I mean litterally with the windows down and sunroof opens it sounds/feels like someone is sucking the air out of your ear drums...borderline painful.
So you cut off the face of your box and then modded the internal piece that guids the air behind the filter? Have any pics of this? Not sure if the induced intake roar from the box being cut open is better then the quieter flow that I used to have...seems like it is better but who knows for sure? My take was the swiss cheese method disrupts airflow more but then I read another article that said a few well placed 2 inch holes are better than no cover at all? Who knows? I took the gamble, air box lids are cheap. -Jeff nolift911@hotmail.com |
I wish I had a pic of my airbox to show you guys, but that piece is at my parents' home. I did what I did to improve flow by minimizing the restriction at the mouth. The reduction in turbulence is probably why I did not hear any strange sucking noises. My airbox was cut with three large trapezoidal holes. I think a bunch of small holes is more restrictive and bound to make some strange noises which could resonate within. Later I switched to a Broadfoot Racing cone intake which sounded also the same, no strange noises. But then I also put on a MAF with a big bell mouth intake and still no strange noises to me. But then, what is noise to others is music to me, so who knows. Or perhaps my hearing is shot from all the loud music I have been exposed to over the years. :eek:
Just make your own adapter plate for a cone filter. I saw that they were charging like 200 bucks for a adapter with filter for my 88 3.2L, just took some spare plate metal trasfered the openings for the gasket onto the metal then drilled a couple holes, including a 3" hole w/a bimetal hole saw for the filter then welded a small section of 3" exhaust pipe that i got for free from a exhaust shop, went out and put on a cone filter i picked up from a local parts store, $25 bucks for the filter and an hour later i had a new filter and adapter. I did this because my original filter housing had cracks in it after the K&N that was mounted in it. Resulted in odd ball power surges under full throttle acceleration. The new system definately adds a quicker snap to the throttle.
Almost all the autoparts chains now have a flat plate with the appropriate (3in?) flange-if you need to modify the bolt pattern, have at it. Or pay some high dollars to MSDS or Powerhaus or whoever.
They all whistle at certain throttle openings. |
When Bernd Andritzky of BMW was dyno testing some of the chip mappings we were working on, two dyno runs were performed on an U.S. spec 89 Carrera with and without the airbox cover. It was fitted with a Euro premuffler, and the chip was the same on both runs. Here are the results of the two runs. These particular runs were runs #10 and #11 and were 10 minutes apart from each other. The first run, #10 is with the stock airbox cover. The second run is with the cover removed. Comparing the runs shows a 0.7 rwhp loss with the cover removed. But that could be dyno tolerances, or my theory is that the warmer air cycling inside the motor compartment on a static vehicle on a dyno is reducing the hp with the less dense air. On a moving 911, this could be different with the turbulence behind the vehicle drawing cooler air into the engine compartment. With a tail Bernd theorizes that even cooler air denser air may be drawn in. Obviously these were done on a German dyno, and the rwhp #s don't correspond to U.S. dynos, so don't try to compare this to a different dyno. Anyways, here are the two runs:
Run #10 with airbox cover http://forums.pelicanparts.com/uploa...1069140420.gif Run #11 without airbox cover http://forums.pelicanparts.com/uploa...1069140432.gif |
Interesting to see these German test-results. Note that, on result no. 11 (with lower bhp figures), the air temperature is 19 (iso 20 on no. 10) and ... the oil temp. is only 16, respectively 17 degrees centigrade. Those are very low oil temperatures! Does that mean they do those full-power tests with a cold engine?? In fact, how can it be that the oil temp. is LOWER on the 2nd test. Just some curious things...
No Paul, the engine was actually pretty hot, with each run after another in 10 minute increments. The oil temp sensor was just not hooked up and is just measuring ambient air temperture.
