Strut removal from A-Arm Ball Joint
I have Bilstein Struts and expected to see a bolt that pinches the strut to the ball joint. But What I found is what looks to be a pin that is flush with the strut on one side and has threads with a 13mm nut as it comes out the other side of the strut bottom. How do I remove this pin? Does it just tap out with a punch?
I want to maker sure before I start breaking things, Thanks |
Yes, jsut tap it out. Use a new one on reassembly if possible. At least dress it flat on a ginder.
Ok, I will soak it in WD-40 Tonight, Thanks......
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Humm? Are these the later - less preferred Bilstein struts. My last 911 had Koni struts which had a bolt. Obviously the Bolt is much easier to remove. Do all Bilsteins use a pin configuration? If not which year did.
911.341.119.06 1972-1989
