MFI blues
My T starts a little rough which i know is normal from what i hear but after its warmed up at low rpm it stumbles.pops out of the stacks once it gets above 3 thousand rpm shes great. So what does that mean ???
72 911 82 911 70 GTO ![]() 97 GT Ragtop 74/76 Jeep cj's |
My first guess would be air leaks.
Gaskets at the base of the stacks (2). Perhaps the throttle plates are too worn. With MFI (and every other form of induction) perfect fit of parts is necessary for great running. Everything that is worn will contribute to the engine being "not quite right". Bob
Bob Hutson |
Air leaks or perhaps timing a bit off? Assuming, of course, all's okay with the engine hard parts...just guessing...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Ichecked the throttle plates and they were seating well before i installed them i couldnt see daylite thru them wjich tells me they were good. It has new gaskets. again once at speed shes great.
Cleaning the dist is a quick easy job that could help.
Also check vacuum from 1 & 4 to the dist. Jeff P.S. Assume the two thermostat hoses are both on.
'72 911T gone '85 TVR |
I'd follow the process outlined in the MFI troubleshooting documentation ("Check - Measure - Adjust". First I'd confirm that the engine is mechanically in good tune and that the ignition is timed correctly. Then I'd start poking around looking for air leaks with all of the usual suspects, gasket surfaces, throttle shafts, etc.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
