Senior Member
Zendalar's Avatar
No turning back! (removing paint)
Project is indeed on the way, these are day old pictures so there has been more paint removal..Gotta get myself a real digital camera and not some crappy mobile phone "camera".
I got the flares detached in one piece...the problem is how to get them back on And rear windows still has to go, seals and window in one piece
Projects:
911 -72T EFI "964-look" "Smoky"
914 -71 1.7 D-JET "Rusty"
Old 11-18-2003, 11:29 PM
Not Quite Banned
Thomas Owen's Avatar
Good start - keep up the good work.
Regards,
Thomas Owen
1972 911T
1972 911S
Old 11-19-2003, 05:52 AM
Pragmatic Dreamer
larry47us's Avatar
Looks scarey to me!!! But I give you credit. I haven't started learning how to do this stuff yet. Keep us posted. How much are you planning on doing to the car?
larry
2004 - 911 - 996 Targa - Dark Teal Metallic, with Natural Brown Leather interior.
1973 - Viper Green 911E Targa - Kermit - gone but not forgotten
Kermit's Short Story and Pix 911E Website
Early 911S Registry Member #537
Old 11-19-2003, 05:55 AM
Senior Member
Zendalar's Avatar
Basically I will do all the stripping, welding etc. Will also shoot the base paint myself...
Paint will be a metallic , dunno which colour yet The cost will be the cost of paint and other supplies, so not much. Lucky me the Porsche (targa especially) has surface area way less than "normal" car.
Will keep posting pictures
PS: I think the "best" places on that car had 5-6 layers of paint and bondo.
Projects:
Old 11-19-2003, 06:30 AM
Somewhere in the Midwest
MotoSook's Avatar
What did you use to cut the old flares off? I'm planning my own surgery
Old 11-19-2003, 06:54 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Keep up the good work...when I did mine there was a huge piece of bondo on the right rear quarter just behind the door.
When I removed it...the door stuck out a little...so I just adjusted the door stop.
It looks straight now...so I assume the PO had applied the bondo to fix the door problem!
I had about 3 layers of paint...but the big problem was the tiny pits of rust in the bottom layer of primer.
It appeared that the car had been left out in the rain when first primed...then they shot more primer over that to cover the rust!!
It was lucky that I decides to strip completely....or I would have lost the car.
Bob
Bob Hutson
Old 11-19-2003, 06:57 AM
Senior Member
Zendalar's Avatar
I used a heatgun to remove all the bondo around the flares, the fiberglass does not mind the heat, unless you heat the flare excessively.
The flare had been sandwiched over the metal part, so i had to cut the resin with this electric saw from inside the fenderwell. Then i just inserted (with help of hammer) thin blade between the flare and fender. POP! it came off.
I tried stripping with all kinds of paint removers, forget those. Heatgun + spatula is the way to go. If there are fiberglass flares underneath, the paint remover usually destroys those too.
Projects:
Old 11-19-2003, 07:26 AM
Zeke's Avatar
I think your cell phone camera works good.
Old 11-19-2003, 07:32 AM
Harlan Chinn's Avatar
Your progress looks great. Is it the photograph or is the sheet metal of the rear fender that "cobbley"? Are you going to replace with metal flares or back to fiberglass? If you do metal ones, I'm sure you already know to butt weld them on. I have seen too many repaired areas which people have lapped joined the metal and had rust develop in those areas. Keep going and keep up the photographic documentation if you can borrow a camera.
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 11-19-2003, 08:45 AM
looking good! you'll know the condition of the car after your strip. i put a thin layer of wax on the area i stripped, asap, to prevent rusting...which doesn't hurt cuz you'll need to block to metal later and then you can prime after you metal block. it sure minimizes the pit rusting
Old 11-19-2003, 08:55 AM
