Oil level makes no sense
I just checked my oil level via the dipstick after running the car for about 20 minutes.
I made sure the car was on level ground, and the engine was running at idle. My oil level gauge seems to be pretty low , almost touching the red area, if not slightly touching already. The Druck Press shows 3.5-5 bar without too much issue when driving the car. Now then, the dipstick shows that I'm almost at minimum oil level! What gives? I had the oil changed less than 600-800 miles ago and my garage area shows 0 fluid drippage *anywhere*. Soooo...what's going on? Oh...the dipstick oil leaves a yellowish stain on the napkin when I checked it...not sure if that is normal or not.
2014 Porsche Cayman S 2001 BMW 525i Touring 1996 Porsche 911 (Gone to Germany) '86 911 Carrera (Gone to Aruba) |
Never rely on the gauge! You need to drive the car and get it to operating temp then check the oil w the dip stick w the engine running on level ground. Depending on the engine and oil coolers it probably holds 9-12 quarts of oil. that oil level gauge that porsche invented was a blunder, but then they still are the best engineered cars in the world bar none
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
If it shows on the dip stick then dont worry you wont blow er up. add 1 quart and check again if you mid range on the dip sick your OK Dont overfill............
Ok...I'll add a quart in the morning and take her out for another 20 minute run.
Did you do your own oil change? If not, maybe they didn't fill it to the level you like. I like to keep mine midway between low bar and high bar.
You didn't say how many miles were on your engine. Before my rebuild, I'd burn a quart every 600-800 miles.
1982 Porsche 911SC Coupe 1999 Porsche 911/996 Coupe |
any blue smoke on de acceleration to acceleration?, Valve Guides?? Rings??
I was getting a small amount of smoke from the exhaust when the car first starts up in the morning, but nothing major. I installed a SteveW chip yesterday and have noticed more of a 'smell' yesterday and more smoke than normal. I'm working with SteveW on that issue and that should be resolved soon, either with a new chip or some other way. This is what got me wondering and made me check the oil, etc.
I had a valve adjustment done about 600-800 miles away and the mechanic said everything was perfect. Oh, as for *blue* smoke...I don't really know. I can't see the color from the smoke today, but the smoke I usually get (before the chip) is not blue.
The red zone means it is a quart or two low which doesn't really mean diddly when you've normally got 13.
Sounds like you've got nothing to worry about, completely normal. And different levels of warmness can make a huge difference in the oil level.
Hey Moazam,
Can't find my notes right now from the Woods/Anderson class we took but I think they said not to pay any attention to the oil level guage as it's meaningless. Instead keep your eye on druck pressure - the higher the better. Also, all Carreras burn oil and the factory wouldn't or couldn't say how much is too much. I think 1 quart per 1k miles is about right but am not sure. My wife's Carrera burns 1 quart per 800 miles and the PPI gave it a clean bill of health so I'm not worried and I don't think you should either. Chris |
I don't know about your guys, but my oil level guage works perfectly. After a few oil changes and checks, I can predict what the dipstick will indicate based on the guage.
Doesn't mean I won't keep checking at the engine, but the guage works fine. |
Since it hasn't been stated yet forgive me for saying the obvious. From the factory our air cooled 911 were said to burn on average 1 quart per 1000 miles. Some people claim to burn much less but 1 quart per 1000 seems to be fairly typical. How closely do you track your oil consumption and your oil levels? Could it be it was a half of a quarter quart lower than what it should have been at the last oil change?
Keep a log and see if your oil consumption changes or if its a little better than you think. Right off the bat I wouldn't be extremely concerned. If it is burning a quart every 600 miles, that is excessive. 170,000 miles is fair distance.
1979 911 SC Targa http://www.pelicanparts.com/gallery/Mike_Kast |
Mine works well too Mr nostatic
So for now, my plan of action is to start logging my oil consumption, add 1 quart tomorrow, keep running the car with the current SteveW chip for about a week. If I still get this smell and maybe more smoke, I'll probably have to get SteveW to get me a slightly different coded chip. Hopefully that won't happen because I'm really enjoying this chip.
Also, different oils will have different burn-off rates. If you changed brands or types, that could explain the sudden rise in consumption. I have noticed that synthetic (Mobil 1) oil burns off noticeably quicker than most dino oil as well. The extra protection, lower internal drag/friction, and longer service intervals are worth it to me though.
I bought the car at about 170k miles and have put on another 2k miles after that, so I haven't had it long enough to log oil consumption, etc.
My oil level gauge works fine as well, no problems when the engine is on temp. and I let it run on idle for a few minutes and then check the oillevel on the stick it is exactly the same as on the gauge. Strange though Porsche fitted a level gauge and then tell you not to use it?
Regards, Gerko 911sc 78 |
make sure the frnt cooler is hot before you check the level,
Rich ![]() '86 coupe "there you are" |
