-   -   How to remove one part of window trim (http://forums.pelicanparts.com/porsche-911-technical-forum/136324-how-remove-one-part-window-trim.html)
pryord 11-18-2003 02:36 PM
I searched the archives for instructions on removing the lower piece of window trim on the doors. I'm describing the black piece that runs parallel to the window and sits on top of the door. Several people wrote that this piece was spring loaded and could be removed without taking the entire window frame apart. Can someone give me specific "how to" directions? I've examined it and I don't see any way to remove it.
Thanks,
targa80 11-18-2003 03:35 PM
I would suggest using a narrow putty knife with some tape wraped around the end so you won't scratch the paint. The trim is held in place with clips that fit tightly into holes on the door panel. Just pry upwards starting at either end.
pryord 11-19-2003 10:33 AM
Thanks. That's what I needed to know.
