Fiberglass fan?
I was brainstorming with the guy who makes the RS heater bypass tubes as to what other bits we could build and market. One idea that popped into my head was a fiberglass fan, either the 3.6L stype or the sought-after 275mm unit. I'd want to make something that looked like the old factory fiberglass fans.
Thoughts? I wonder how much of a performance gain - if any - this would give. Is anyone else already making them? I'll be honest and tell you up front that I have no idea what the flow characteristiics of these fans are.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
I wonder about durability. Yes they would last for a 24hours race, but will they last 10-15 years. Still, it would be very cool.
Re: Fiberglass fan?
(sorry put your puke buckets down, no more eram jokes) The stock unit is pretty light, I don't think it would be a huge savings. The coolness factor would certainly be there! |
It always seemed rather incredible, that from the very start with the original 2 liter 130 hp engine...right up to later versions that were almost twice the size and maybe close to 3x the hp...the fan design did not change all that much ( sure...pulley ratios changed a bit and there were two different...but still very similar diameters)... all these fans developed about the same air flow ( +/-)...around 1200-1500 liters / sec or minute.
If you'd do a new design, I would like to improve the aero characterisitics, such that we can get close to double the original airflow with about a 1.5 x factor increase in fan hp....it would match today's higher hp ( heat rejection) motors better. I wouldn't just mimic the original design... ---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
A CF fan to match the CF air tube would be very sweet. Make one and I'll be your first customer. |
Cut the blades of the stock fan, and , nevermind, handlayup of blades will never work. It would have to be an injection molded piece. think about the balancing needed. back to sniffin styrene....
Damon @ SERIES 900.com Sunapee NH several 911 variants |
What are the ultra advanced fan/props in today's jets made out of?
I don't think CF or FG would be viable materials to use.
Warren & Ron, may you rest in Peace. |
Senior Member
The fan blades are too small.
What you need to do is to relocate the alternator to a more conventional location (Like the AC). Then you can have a fan that doesn't require that huge alt. housing and could have more blade surface. I wonder if I can get a hold of a primary compressor blade fan from a small Pratt-Whitney or something... yeah...yeah...thats the ticket!
-- Chief Architect and Mastermind, SCWDP |
SCWDP- Shock and Awe Dept
I agree that the fan is already light and not really where I would want to risk strength or durability. There a lot of 30+ old fans out there that are still good as new. It is also an efficient design, not unlike turbo jet/fan compressor blades, the blades in the engine not the fan you see from the front.
Thom, maybe CF engine tin? I bet you could loose a few pounds there and you would never worry about rusted tin again. I’ll see what else I can think of too.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Other thoughts I had was a lightweight version of the little cover under the fuel pump/steering rack, but I think most people just throw it away and run without.
Isn't there already a cf engine tin?
The fan can be done, the old racecars used f/g fans.
The alternator is not really that much in the way. Remember that it is the outermost part of the blade that is moving the fastest/furthest and doing the bulk of the work. Look at some of the air racers of the early thirties. Barely 15% of the blade radius projects beyond the cowling. The "surface area" of the propeller disk projecting beyond the cowling, however, is much greater than 15% as is the thrust generated by that part of the blade.
I'm sure Island 911 will chip in with some formulas.
Jamie79SC |
Regarding Jet fans:
"Typically titanium, aluminum and stainless steel have been used in the fan blades. Titanium is currently favored because of its light weight, corrosion resistance and good high cycle fatigue properties. Future planes may use fans with polymer (plastic) matrix or ceramic matrix composite blades." From http://www.madsci.org/posts/archives/mar99/921908947.Eg.r.html
Stahlwerks.com
RC airplane props are molded out of glass filled nylon, and some are CF. Airfoils get pretty complex and they handle 20k rpm and up sometimes. I'd say it could be done, but it wouldn't be cheap.
I like the idea of relocating the alt and using a smaller already existing fan, good use for an "eRam"
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
How about converting to water cooled heads and mounting an electric fan in the rear?
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler |
Quote: "How about converting to water cooled heads and mounting an electric fan in the rear?"
You do that and I'll give you the 996 decal.
masuram sees old F/G fans
these would have been built in 2 or more piece pressure molds, not hand layup. If Thom wants some bling bling, you could cover the stock blades with CF and layer up some resin on top and sand , clear and buff, BLING BLING...
Those 959 decals are too expensive. ;-)
