126coupe's Avatar
Piston
An old German engineer who trained me to build race motors says always polish the tops of your pistons to a bright shine. not only does it make for a better combustion but when it comes time to refreshen they clean easier. This is a Mahle 89MM racing piston that will become part of my 2.5L Screamer
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 11-18-2003, 11:00 AM
Nice!!!!!
When you say "polish", do you mean bead blast, or hand polish (which I doubt)?
The concept sounds valid; as we are about to unbutton my engine for valve guides and piston rings, this sounds like a great idea.
However, too bad the Concours judges will not be able to appreciate this........Andras
1983 911SC Chocolate Kiss (Smokey Quartz Metallic)
1991 VFR750F
1982 VF750S
Miata (wife's)
Audi A6 Quattro (family)
Old 11-18-2003, 11:05 AM
126coupe's Avatar
Hand polish definetly!! get the carbon off by soaking in carb cleaner. its kinda tedious w older pistons, easy w new pistons. Clean and polish the combustion cham,ber on your heads too!!
28' Pace Trailer
Old 11-18-2003, 11:13 AM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
What do you guys recomend to do the polishing of the heads and piston tops?
Wetsand? Polishing compound? Special buffing pad?
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 11-18-2003, 01:04 PM
126coupe's Avatar
Once you get all the carbon off you can start w a buffing wheel on a dremel or small drill motor. Be careful though you only want to stay on the top part of the piston. I finish them by hand w a nice terry cloth rag and some metal polish. Of coarse you want the rings out and labled
28' Pace Trailer
Old 11-18-2003, 01:10 PM
David's Avatar
I've had the best luck with Simichrome polish. It comes in a yellow and red tube or can. It's made in Germany which can't hurt either.
Old 11-18-2003, 01:46 PM
I would mask the ring land area with heavy tape, then polish with a buffing wheel and tripoli.
Sherwood
http://members.rennlist.org/911pcars
Old 11-18-2003, 03:46 PM
126coupe's Avatar
The masking idea is a great one!
28' Pace Trailer
Old 11-18-2003, 03:56 PM
what are you going to gain? i can't see it.
206 637 4071
Old 11-18-2003, 05:17 PM
126coupe's Avatar
When a german from Berlin named Volkar who has engineering degrees all over europe Who worked with Vasek, Siffert and the like tells me to polish the top of the piston. I polish the top of the piston!!
28' Pace Trailer
Old 11-18-2003, 05:21 PM
Send a message via AIM to Oldporsche
Cool
Could be the theory that it will reflect power?
I do know that the race team of Robert Yates, NASCAR, somehow experimented with ceramic coating of the combustion chamber.
This was to reflect the heat of combustion?
David Duffield
Old 11-18-2003, 05:58 PM
Advantage? On second thought, maybe less of a tendency to accumulate carbon. Performance-wise, probably not much. People seem to covet very shiny and pretty JE pistons.
Ceramic coating has it's place in reducing heat transfer to the cylinder heads and pistons. Not sure about the current technology or effectiveness of ceramic coating the combustion chambers. If it works, there's potentially more power to push the piston down rather than heat energy lost to the cooling system. Early coating attempts resulted in major flaking.
I don't think PAG embraces ceramic coating as much as some engine builders and race teams do. The later Pcar engines have ceramic-lined exhaust ports; maybe more for emissions than for power.
Sherwood
Old 11-18-2003, 11:14 PM
Cool
when I was investigating EGTs I found out that if EGTs see over 1,400degF then coat the piston domes.. Some engines see 1,700degF, like in big hp turbos. I may be able to find what a dyno turbo tuner wrote if needed.
........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-19-2003, 05:34 AM
Senior Member
Jdub's Avatar
There are contrary opinions on this.
Creating a smooth surface prevents particulate from adhering to "hooks" in the metal that are essentially not there due to polishing. However, once you do build up an even covering of carbon (inevitable) it is very likely that a piece will break free, thus exposing a single part of the original metal to the heat where the rest is covered. This is a hot point on the piston and not a good thing to have.
I have heard an even, "hooked" surface is ideal. I am on the fence, as shell-blasting or scuffing piston tops sounds like trouble to me. That said, folks who hold this opinion believe that you don't build an engine in anticipation of the next rebuild, so there is no point in creating a smooth surface for cleanup down the line.
On a side note, I dead-time Triumph/Norton motorcycles using magnetos using a timing stick attached to a dial gauge (the stick touches the piston top). One oldtimer told me to never scuff the surface of a piston via the stick or I'd expose clean piston top where the rest is covered. I guess this goes along the line of the my first comment above.
John
'78 Targa in Minerva Blue
Old 11-19-2003, 06:28 AM
Is carbon a desired insulator in this case? If so, maybe we should apply an even layer onto the piston top before installation. :-) Just playing devil's advocate.
A few months ago, many folks tried cleaning their combustion chambers with a spray of water into the intake (engine running). It works. If the piston dome/combustion chamber is smooth, carbon should come off easier.
Sherwood
Old 11-19-2003, 10:06 AM
304065's Avatar
The reason for polishing piston tops is to smooth out the surface irregularities that could cause preignition-- you don't want any sharp edges, for example, where the valve reliefs are cut in. Visualize a sharp edge as a mountain ridge-- where the metal is thin near the top, it tends to heat to a high temperature which can be a source of preignition.
I'll admit that it would have to be pretty extreme to do it, but that's what I've read.
You build an engine like this you are spending $20K, what's a few bucks more to polish the domes?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-19-2003, 10:25 AM
