Fuchs Offset Help
Need some help on my 6 X 15 Fuchs. I have 3 that are marked # 911 361 020 that take the ring type centercap. I have 1 that has the same part number but takes a 3 prong centercap. Does anyone know if these are the same offset ? I measure best I can across the back of the tire to the mounting surface and all seems the same. Did Fuchs change the centercaps only ? Thanks for the help on this. Steve, sturco1@twcny.rr.com
All of the 6' Fuchs, whether 15 or 16", have the same +36mm o/s, there are a lot of little changes though, as you have found out.
Thanks guys. The offset was my biggest concern. The very minor chages I can live with. Thanks again, Steve
| All times are GMT -8. The time now is 10:48 PM. |
