Thermostat question
I noticed on the way in to work today that the oil temp never reached 180, 160 seemed to be as high as it would get. (Cool Chicago day) I am beginning to wonder if my thermostat is no good. In the summer, if I drive on the highway for a long time. it will heat up to 210 - 220. Now with cooler weather, it does not seem to reach 180. This makes me think the thermostat is stuck open.
This is a 69T with a 2.2T that has some modifications, no front oil cooler and a 930 style tail that is completely open for air to flow to the engine. Do you think it is possible the thermostat is bad? Is it just not developing heat due to the amount of air flow over the engine? Thanks
Keitho64 05 GTO 00 911 C2 64 Corvair Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles |
you could put the sender in boiling water attached to the gauge
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Could be normal. How long did you drive and what was the outside temperature?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Outside was 45-50, I drove 35 miles mostly at 3,400 RPM
