I would appreciate some help identifying these oil tanks. I've done quite a bit of research and have labeled my educated guesses. Can anyone confirm or correct?
I am working on an engine test stand and will pick one to use for that. I am thinking the one bottom left is the best candidate. It appears to be the least valuable, has fewer ports to deal with than the one bottom right, and a couple mounting points built in. Thanks. ![]() |
Go to posts 6 and 13. The bottom right would have least value to collectors.
https://forums.pelicanparts.com/porsche-911-technical-forum/1124699-sc-vs-carrera-oil-tank-differences.html
Ed 1973.5 T Last edited by E Sully; Yesterday at 10:25 AM.. |
930 107 006 00 930 107 006 03 930 107 006 04 930 107 006 07 I think the two additional ports are an indication this was meant for Sportmatic. ![]() |
The one lower left, labeled 73-77 is a 73 one year only.
Not Sportmatic. It is from the '80's and probably for the 930 Turbo models.
Ed 1973.5 T |
Screenshot of a 1986 Slantnose 930 oil tank.
Ed 1973.5 T |
Tags |
engine stand , engine test stand , oil tank |
