-   -   Troubleshooting an SC CIS problem (http://forums.pelicanparts.com/porsche-911-technical-forum/136839-troubleshooting-sc-cis-problem.html)
vash 12-12-2003 06:17 PM
nice job finding the problem, the spring on my brandnew POV is mousetrap strong. you think a thicker o ring will skew the lid? i am with RUF i bet your's may be defective. was it hard to remove?
SpeedracerIndy 12-12-2003 10:15 PM
Not too hard to remove, but a little messy. I just chipped away the epoxy I used, cleaned it really well. Then scuffed up the edges so that the new epoxy would stick better. My o-ring and valve look fine, but the spring does seem to be weak. On a thread over on rennlist the poster used a mousetrap spring to strengthen his lid. I was planning on trying this first.
echrisconnor 12-15-2003 07:28 AM
Have you tired re-seating the o-ring using the door. If you pull the ring out and then use the door to push it back in place you get a perfect mating surface. With a perfect mating surface you don't need a strong spring.
c
