A few drips - oil
A couple of years ago I had a few drips of oil, the hose on the oil cooler was half a turn loose.
Whoops sorry, it's a 1972 T. I assume it's the same prob as it's the same place. I'll know for sure when it goes up in the air for it's winter oil change and to be swepco'd. It's the right side lower of the oil cooler which O Ring do I need is it : 704 172 50 or 704 173 50. The small one or the larger one. I tried looking at the diag but did not help. I assume this O Ring is a ten minute job! And yes I did change my trans oil in the spring in prep for sepco. Thanks Jeff
'72 911T gone '85 TVR |
