901 Gearbox
racing at willow thais past weekend i was having a lot of trouble Up shifting to 4th gear, Downshifting no problem. I was going from 3rd to 5th and everything worked out fine. Any idea's??
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
Yeah, I know what happened.
It is called CARMA. Maybe next time you will be nicer to your good old friend. Does it work when you are at a stop? Maybe it just got to hot. (the tranny that is) Mine has done that in the past. Or maybe the 901 does not like the 2.4 HP you are putting through it..
Mark Scott Vintage 911 Racer 1967 911S 2.4L ROCKET Powered by Faragallah! www.scottassociatesracing.com |
I have a 901 in a 914 race car but the same has happened and it was due to the joints in the shift linkage moving ever so slightly. 1st and reverse seemed slightly easier to get into at the same time. Especially the clamp joint on the splined shaft that attaches to the shifter. I started using a Rennshift (James Adams in TX) and it has a much better clamping force on the shift rod and has stops that take the load off the linkage.
Talked to some experts general consensus is a linkage adj. I use a FAB car shifter and switched back from all solid mounts to rubber mounts. That and the combo of T7 elevation change could be the problem. Ill jack up the rear and go through the gears in my garage and see if I can adj it out
You should of kept those solid mounts in there.
