-   -   Might as well flush $7 down the commode (http://forums.pelicanparts.com/porsche-911-technical-forum/137197-might-well-flush-7-down-commode.html)
SeaDweller 11-25-2003 10:03 AM
Stuff like this just irritates me to no end......
Part number 24A on the diagram has to be in the top 5 of the most retarded parts on my car. It's a rubber cylinder that mounts to the engine lid hinge, and provides an isolated mount for the A/C line clamp. The studs are moulded into the rubber on each end, which is brilliant.........:rolleyes:
The stud on mine had ripped out of the rubber, so I ordered a replacement. This part had evidently failed within a week of the car's delivery back in '85, because I noticed that the A/C hose has worn almost completely through from rubbing on the lip of the engine bay when the lid is opened and closed. This mount secures the A/C line, and is supposed to keep it from doing just that.
I installed the new part, and was concerned that there was a tremendous amount of tension on it, due to the routing of the A/C line. Well, one day later, and the stud has already sheared from the rubber, leaving the A/C line unsecured, and rubbing against the sharp edge of the engine bay again.
Why would you design a part in this fashion, when it's under so much stress from the whacky routing of the A/C line? After replacing it, I knew it wouldn't last a week. Looks like a custom part is needed......
Yeah, yeah, I know, Porsche's ain't supposed to have A/C in the first place, but I'm still running my A/C here in FL...........:D
http://forums.pelicanparts.com/uploa...1069783176.jpg
LeeH 11-25-2003 10:23 AM
When mine broke I dug through my garage cabinets and used a long bolt with a piece of black rubber hose as a spacer. It works the same, looks the same, will never break again, and best of all - cost nothing.
yelcab1 11-25-2003 11:25 AM
The superior intellect of the Porsche engineers strikes again. Must be the same guy responsible for the headstuds.
scottb 11-25-2003 12:00 PM
I had a similar part on the exhaust system of my old Jensen Healey. It broke. My fix was the same as Lee's....a long bolt left a bit loose.
ZCAT3 11-25-2003 12:46 PM
I recently replaced the AC lines in my 87 and although all the little holders were still intact (including part 24A - which I agree is a very poor design) the old lines were very badly worn at the deck lid edges. When I replaced the lines I went out and bought a few of those wrap around plastic hose protector sleeves at NAPA Auto for a few bucks each. This is a much better way to protect the lines from the sharp sheet metal edges.
targa911S 11-25-2003 01:23 PM
What IS air conditioning?
Schrup 11-25-2003 01:34 PM
It's that 80lbs of crap I ripped off my car last week. :D But then again I don't live in Florida
howie944 11-25-2003 09:57 PM
Is this the same part that is also used between the air pump mounting arm to the fan shroud mounting bracket? Sure does look the same.
..P 11-26-2003 06:53 AM
Buy a K&N filter, that way you can flush $57 down the commode, get nothing in return except more dirt in the motor. Now THAT's a deal!!
P
rcwaldo 11-26-2003 08:03 AM
those type of mounts are called "lord" mounts. Available from McMaster-Carr http://www.mcmaster.com/
Check page 1210.
Another tip to not use locking type nuts on them as they wont live long if twisted upon installation...
Chris
toolman 11-26-2003 12:55 PM
Mine was rubbing along the deck lid opening too, I just slightly bent the pipe downward a little and VIOLA!!
scottb 11-26-2003 02:46 PM
Does anyone know which of the McMaster mounts is equivalent to the Porsche mount?
Jeff Alton 11-26-2003 03:40 PM
If this is what you need, send me your address and I will mail it out to you free of charge.http://forums.pelicanparts.com/uploa...1069890004.jpg
