What's with all of the electrical gremlins Lately?
Saturday, my turn signals, brake lights, & backup lights took a dump! Flashers work, parking lights work, High & low beams work. I removed the steering wheel, & checked the turn signal switch that I replaced a year ago, & everything looked ok. also checked the fuse panel, & it looked ok. any suggestions? Thanks, Craig
80SC Last edited by Craig Stevens; 11-25-2003 at 03:17 AM.. |
It seems that whenever someone has an electrical problem, the gurus on the board say "check your ground straps." So....check your ground straps.
1984 Targa |
Green Skull 006
I had some strange electrical gremlins when my alternator and voltage reg. were on their way out.
S Reg 823 R Gruppe 246 1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha" "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field. |
I was just helping a fellow troubleshoot this exact same problem on a '74. In his car, all three of these came off the same fuse..#11 in his case. I don't have the wiring diagram for your car, but there are very many similarities between his and you car. Try to determine which of your fuses carries all three of these problems and start there. Check the fuse and check to make sure there is a tight connection. Clean the fuse holder. An ink eraser does a good job of this.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Well, thanks for the ideas. I guess I will be spending this weekend chasing the problem. Craig
80SC |
I think it was your son (that guy is fast) ripping you car apart at Sebring!!! Hope you find the problem before Road Atlanta!!
Wouldn't be the first time you broke something of mine, would it Tim? and not the last either!! Yes, it must of been the fast part, or could it be the trail braking, fluid boiling part? Craig
80SC |
fintstone, spot on!! #11 fuse fixed the problem!! Thank you, Craig
80SC |
No charge my friend!!
Stoney
