PMB Performance
Oil Lines Needed?
Hi Gang,
I just finished installing my jailbar cooler and hardlines. I need the hoses from the thermostat to the tank and engine now. I have the hardline for the engine. This is a 71 car. Is there a difference with the hoses out there and the earlier vs. later tanks? The tank is, of course, a 71 tank. Thanks in advance, Eric
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com |
There is a difference. Your tank has a 26mm fitting, later setups had 30mm. The easy way to do this is use the 30mm hoses from a 74. I assume you are using the 74-89 style thermostat and lines.
You will need a 26mm to 30mm adapter at the tank. Pelican has the part here: http://www.pelicanparts.com/catalog/shopcart/911E/POR_911E_oilsys_pg3.htm#item6 You will also need a 30mm union at the case. With that, the 74 parts are a simple bolt in.
Chuck Moreland - elephantracing.com - vonnen.com |
PMB Performance
Thanks Chuck,
That looks like the ticket. Is that Brass or Gold? Any 914-6/GT hard lines yet?
Gold plated
![]() Nothing in que for the 914
