chain tensioner
Hi all,
I just took the chain tensioner covers off to do the upgrade and I noticed wear on the huosing by the cahain on the left side. What could be causing this???
The wear is by the numbers 1,2 and 3 hope the pic comes through
bk
Old 11-28-2003, 10:41 AM
Cool
Wow
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-28-2003, 12:29 PM
Have you had this apart before?
My guess is that only one side of the double-row chain is in mesh with the intermediate shaft sprocket.
Sherwood
http://members.rennlist.org/911pcars
Old 11-28-2003, 12:50 PM
maybe the cam sprocket is not in alignment
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-28-2003, 12:56 PM
I have not had this apart before . there are no aluiminum filings or signs of wear on the chain. is it possible someone had been in there before??
Old 11-28-2003, 01:16 PM
I'd be surprised if no one has been inside before. Factory chain tensioners don't last that long. Does your chain have a removeable link? If so, that would indicate the chain has been replaced for one reason or another. BTW, how many miles on yours?
Sherwood
Old 11-28-2003, 01:53 PM
As I rotated the engine I could not see a link but the chain was tight and stayed clear from the housing. I suspect you are probably right about someone being in there before , who knows?
the car has 79000 mile on it, and not very many records were kept.
Old 11-28-2003, 05:42 PM
