Halm's Avatar
No hi-beams
Three weeks ago, somewhere between Phoenix and Charlotte, my high beams stopped working. Low beams, turn signals and flasher all work. My fog lights also don't work, but I think I am responsible for that when I removed one for adjusting.
I have check the fuses and even replaced them. I thought it might be in a bad turn signal switch that had been slowly going bad for sometime, so I replaced that this morning. Still, no hi-beams. The headlights are H-4's. Is there a relay I am missing that may have died? Any other areas to troubleshoot?
Any and all ideas welcome!
'17 Cayenne
Old 11-28-2003, 09:45 AM
jbripps's Avatar
I've had the same problem, on and off, for a while too. Do yours turn back on after some time? Mine sporatically don't work, while lo-beams are always fine.
regards,
Jon
'85 Targa (recently acquired by Coollx)
'02 Carrera 4S (holy moly...I'm in heaven....in the snow too)
'06 BMW 325i (gone and forgotten)
'03 Honda Odyssey (more dings every day....thanks wifey)
Old 11-28-2003, 09:52 AM
BTDT - your turn signal switch needs to be replaced or repaired. The little contacts in there get badly corroded from the high current flowing thru them.
The long-term fix is to install a headlight relay.
Old 11-28-2003, 09:56 AM
Halm's Avatar
Jon, rears are fine.
Thom, replacing the switch was my expected fix also. Did that this AM. Still no joy.
Going to the local P-Car dealer and will try replacing the relay.
'17 Cayenne
Old 11-28-2003, 10:07 AM
Send a message via AIM to 69 911s
Naturally you have twisted the fuses...
when you see hoof prints, dont automatically assume zebras
Old 11-28-2003, 12:17 PM
Halm's Avatar
Just got back fro the P-Car dealer with a new relay. Still no hi-beams or fog lights. Horn does work.
The insert for Fuse Box 1 is gone so can someone tell me if there is fuse there I should look at.
Thanks.
'17 Cayenne
Old 11-28-2003, 01:54 PM
derek murray's Avatar
Fuse block #2 (eight gang); fuses 1 and 2 are high beams, left and right respectively. Fuses 3 and 4 are low beams, left and right respectively.
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 11-28-2003, 02:42 PM
Halm's Avatar
Double checked all fuses and replaced high beam fuses again. Tried the lights again ans still no high beams. But this time I had no running lights either. After checking all fuses again, I decided to pull the OFF/ON switch for the headlights and make sure all connections were still there from the new turnsignal switch.
Well 2 wires were loose. I thought I plugged them to the correct male spades and checked the lights. Running lights are back, but on second look, I either attached one wire to a multiple spay were it doesnt belong or a wire has disappeared.
Can someone now describe for me the wire colors to spays on the off/on switch? This is driving me crazy!!!
Thanks again.
'17 Cayenne
Old 11-28-2003, 03:05 PM
