North Coast Cab's Avatar
Removal: Engine Cover Sheet Metal
Is there a good picture or schematic of the metal engine cover? It looks like about 4-6 pieces that surround the engine half way up. Mine needs a cleaning and painting, but I'm not really sure if I can get it all off with the engine on a dolly.
John
1985.5 944 GTS
Old 12-22-2003, 06:14 PM
Hilbilly Deluxe
emcon5's Avatar
82 911SC Coupe
GTI Cup #43
Old 12-22-2003, 06:36 PM
Do you know if I can take 1-7 off without messing with all the little pieces?
John
1985.5 944 GTS
Old 12-22-2003, 06:40 PM
don911's Avatar
I just did this on the engine I put in my car. The side pieces and the front piece (fan side) are easily removed. The rear pieces (trans side) had hoses going thru and looked to be a pain. I only painted the side pieces and the front pieces. I just cleaned up the rear since it's not worth the hassle to remove in my opinion.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 12-22-2003, 06:44 PM
I was able to get all mine off with the engine sitting on a few 4x4's. They are held on by a hand full of 10 mm bolts, nothing fancy.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Early_S_Man's Avatar
Porsche Crest
You mean something like this???
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-22-2003, 06:46 PM
Super Moderator
cstreit's Avatar
John, The tin between the cylinders (#14) cannot be removed without removing the oil return tubes. Removing these tubes either requires crushing them and using the expandable kind, or removing the heads requiring a top-end teardown.
Unless they are rusty and disintegrating (potentially causing cylinder hotspots because of air-flow issues) best to leave them alone untill you have to do a top-end job.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-22-2003, 08:39 PM
Don,
We're on the same wavelength. If I can easily get the front and sides off I'd be happy. Nineteen years of crud has left it a little less than desirable.
John
1985.5 944 GTS
Old 12-23-2003, 04:16 AM
I used ss bolts on the sheet metal
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-23-2003, 05:02 AM
don911's Avatar
I suggest Krylon BBQ paint on these pieces. It covers great and is claimed to be good for some rediculus temperature. Over 1000 degrees I think.
Don
Old 12-23-2003, 05:34 AM
I powder coated all the tin on my engine two years ago and it still looks like new.
Bob 80SC
Old 12-23-2003, 01:42 PM
